Dell PowerEdge T340 Intel Xeon E-2124 8GB 1TB
Quicklinx: F6NJWS00 Mfr#: FFCCN
Case Style: Tower
Processor Type: Xeon
Hard Disk Capacity: 1TB
Processor Speed: 3.3GHz
Installed Memory: 8GB
  • Xeon
Hurry, only 1 left in stock!
£777.58 ex VAT
£933.09 inc VAT
Develop your business with the PowerEdge T340 tower server. It is a reliable, easy to manage, and scalable one-socket server. The PowerEdge T340 helps you share and connect quickly across your organization to drive business results.
  • Operate reliably and scale without limits
    The PowerEdge T340 is your reliable server that allows you to collaborate and grow as you scale.
  • Intuitive systems management with intelligent automation
    PowerEdge servers with embedded iDRAC with Lifecycle Controller offer agent-free management right out of the box, delivering smart automation of routine tasks. The T340 is easily managed which frees up time for work priorities.
  • Keep your data safe
    Every PowerEdge server is made with a cyber-resilient architecture, building security into the server's entire life cycle. The T340 uses these security features so you can reliably and securely deliver the right data to your customers. Dell EMC considers each part of system security, from design to end-of-life, to ensure trust and deliver worry-free, secure servers.
Dell EMC PowerEdge T340 - tower - Xeon E-2124 3.3 GHz - 8 GB - 1 TB
Server - tower
Height (Rack Units)
5U
Server Scalability
1-way
1 x Intel Xeon E-2124 / 3.3 GHz (4.3 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
1 x 1 TB (hot-swap) - SATA - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
21.8 cm x 60.32 cm x 47.13 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 5U
Built-in Devices
Status LCD
Server Scalability
1-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
4.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD - hot-swap
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H330
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Express (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 3.5"
Slots
2 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x16 - half-length, full-height , 1 PCIe 3.0 x1 - half-length, full-height
4 x USB 2.0 - Type A , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 2 x VGA (1 front, 1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear) , 1 x management - micro-USB (1 in front)
Bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
495 Watt
Operating System / Software
OS Provided
No operating system
21.8 cm
60.32 cm
47.13 cm
10 °C
35 °C
10 - 80%
Case Style: Tower
Brand: Dell
Price Range Ex VAT: 750 - 1000
