Develop your business with the PowerEdge T340 tower server. It is a reliable, easy to manage, and scalable one-socket server. The PowerEdge T340 helps you share and connect quickly across your organization to drive business results.
Operate reliably and scale without limits
The PowerEdge T340 is your reliable server that allows you to collaborate and grow as you scale. -
Intuitive systems management with intelligent automation
PowerEdge servers with embedded iDRAC with Lifecycle Controller offer agent-free management right out of the box, delivering smart automation of routine tasks. The T340 is easily managed which frees up time for work priorities. -
Keep your data safe
Every PowerEdge server is made with a cyber-resilient architecture, building security into the server's entire life cycle. The T340 uses these security features so you can reliably and securely deliver the right data to your customers. Dell EMC considers each part of system security, from design to end-of-life, to ensure trust and deliver worry-free, secure servers.
- Dell EMC PowerEdge T340 - tower - Xeon E-2124 3.3 GHz - 8 GB - 1 TB
- Server - tower
- Height (Rack Units)
- 5U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E-2124 / 3.3 GHz (4.3 GHz) (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- SATA
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- 1 x 1 TB (hot-swap) - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 21.8 cm x 60.32 cm x 47.13 cm
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- 1-way
- Hot-Swap Bays Qty
- 4
- Black
Processor / Chipset
- CPU
- Intel Xeon E-2124 / 3.3 GHz
- Max Turbo Speed
- 4.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- LAN-on-motherboard (LOM)
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Express (iDRAC9)
- Bays
- 4 (total) / 3 (free) x hot-swap 3.5"
- Slots
- 2 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x16 - half-length, full-height , 1 PCIe 3.0 x1 - half-length, full-height
- 4 x USB 2.0 - Type A , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 2 x VGA (1 front, 1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear) , 1 x management - micro-USB (1 in front)
- Included Accessories
- Bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Nominal Voltage
- Power Provided
- 495 Watt
Operating System / Software
- OS Provided
- 21.8 cm
- 60.32 cm
- 47.13 cm
- 10 °C
- 35 °C
- 10 - 80%
