Dell PowerEdge T30 MT Intel Xeon E3-1225v5 8GB 1TB
Quicklinx: CVX7WS00 Mfr#: 30-0265
  • Xeon
Ideal for small office/home office collaboration, file storage and sharing, and data protection.
By storing and sharing information on a server, the PowerEdge T30 helps you improve access to information, simplify processes and get more done in less time. Overcome the complexity of data and applications and get organized on a central T30 server:
Eliminate misplaced and lost data, images and videos due to "sneaker-net" file sharing. Users can share files and collaborate with central file storage to eliminate the headaches of having multiple copies and versions of files spread out among users.
Consolidate data, images and videos stored on multiple media and media types in multiple locations. With the storage capacity of a server, you can centrally store user data and organize your stacks of DVDs, USB drives and external hard drives.
The PowerEdge T30 server packs large internal storage capacity and capable performance into a mini-tower chassis designed to deliver efficient and worry-free operation. With the T30, data and applications from multiple desktops, workstations and mobile devices can be consolidated onto a single server to boost collaboration and productivity.
Depending on your needs, you can take advantage of the processing power and storage density of the T30 to attain greater efficiency and productivity for your home or office.
Save time when moving or copying files between locations. A server offers faster data transfers compared to external storage, cloud storage or email.
Attain better business-transaction response times.
With its compact size and low sound levels, the T30 easily installs in your small office/home office environment and operates non-disruptively.
Unobtrusive home- and office-level acoustics: The small form factor and deskside acoustics allow you to install it virtually anywhere.
Reduce storage and software costs: Help reduce expenses by loading your data onto the T30 and letting users share applications, avoiding the extra costs of additional external storage devices, cloud storage space and copies of software.
With or without an IT staff, the T30 makes it easy to secure your data and files with software RAID and optional backup restore solutions.
Backup and restore: Easily implement automatic data backup with Microsoft Windows Server.
Easy management: Update software applications in one place instead of on multiple PCs to simplify tasks and save time.
Move your business to the next level with built-in expandability for growth. The PowerEdge T30 can help you:
Easily attach additional devices with up to 10 external USB (six USB 3.0) ports.
Expand flexibly with four PCI/PCIe slots that allow you to grow at your own pace.
Consolidate data and media files with six internal hard drive bays supporting large storage capacity.
Drive applications and media quickly with your choice of a powerful Intel multi-core processor.
Support large memory capacity with up to four DDR4 DIMMs to experience enhanced application response times and crisp video performance.
Dell PowerEdge T30 - MT - Xeon E3-1225V5 3.3 GHz - 8 GB - HDD 1 TB
Server - mini tower
Server Scalability
1-way
1 x Intel Xeon E3-1225V5 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics P530
1GbE
OS Provided
No operating system
17.5 cm x 45.4 cm x 36 cm
11.7 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Server
Product Form Factor
Mini tower
Server Scalability
1-way
Internal Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Ethernet Controller
Intel I217-LM
Remote Management Controller
Integrated Baseboard Management Controller (iBMC)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 4 (total) / 3 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 PCIe 3.0 x4 - half-length, full-height , 1 PCIe 3.0 x16 - half-length, full-height , 1 PCI , 4 (total) / 3 (free) x DIMM 288-pin
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x DisplayPort , 1 x HDMI , 1 x serial , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Pricing Type
Power supply
Power Provided
290 Watt
Operating System / Software
OS Provided
No operating system
17.5 cm
45.4 cm
36 cm
11.7 kg
5 °C
35 °C
10 - 80%
