Enhance productivity.
The PowerEdge T20 server packs large internal storage capacity and capable performance into a quiet mini tower chassis designed to deliver efficient and worry-free operation. With the T20, data and applications from multiple desktops and workstations can be consolidated onto a single server to boost collaboration and productivity.
Get organized
From work to home to the classroom, the T20 helps you improve access to information, simplify processes and helps get more done in less time. Overcome the complexity of data and applications and get organized on a central T20 server:
- Eliminate misplaced and lost data, images and videos due to "sneaker-net" file sharing. Users can share files and collaborate with a central file storage to eliminate the headaches of having multiple copies and versions of files spread out among users.
- Consolidate data, images and videos stored on multiple media and media types in multiple locations. With the storage capacity of a server, you can centrally store user data and organize your stacks of DVDs, USB drives and external hard drives.
Reap the benefits
Depending on your needs, you can attain greater efficiency and productivity for your home or office.
- Save time when moving or copying files between locations. A server offers faster data transfers compared to external storage, cloud storage or email.
- Attain better business-transaction response times.
Quiet, compact and affordable design
With its compact size and low sound levels, the T20 easily integrates into your environment and helps reduce costs.
- Quiet home- and office-level acoustics: The small form factor and desk-side acoustics allow you to install it virtually anywhere.
- Reduce storage and software costs: Help reduce expenses by loading your data onto the T20 and letting users share applications, avoiding the extra costs of additional external storage devices, cloud storage space and copies of software.
Take it to the next level
Move your business to the next level with built-in expandability for growth. The PowerEdge T20 can help you:
- Consolidate data and media files with six internal hard drive bays supporting large storage capacity.
- Drive applications and media quickly with your choice of Intel® Xeon® or Pentium® multi-core processors.
- Support large memory capacity with four DIMM slots to experience enhanced application response times and crisp video performance.
- Enhance flexibility with four PCI/PCIe slots that allow you to grow at your own pace.
- Boost performance with up to 12 USB (four USB 3.0) ports to attach more devices and drive fast video and graphics.
Secure and manageable
With or without an IT staff, the T20 makes it easy to secure your data and files with software RAID and optional backup restore solutions.
- Data protection: Safeguard against data loss with built-in support for file duplication using a software-based redundant array of independent disks (RAID). Error Correction Code (ECC) memory adds another layer of data protection.
- Backup and restore: Add automatic backup and restore functions with the full collaboration suite, Microsoft Windows Small Business Server.
- Easy management: Update software applications in one place instead of on multiple PCs to simplify tasks and save time.
Get organized
The Dell PowerEdge T20 helps you improve access to information, simplify processes and get more done in less time. -
Reap the benefits
Depending on your needs, you can attain greater efficiency and productivity for your home or office. Save time when moving or copying files between locations. A server offers faster data transfers compared to external storage, cloud storage or email. Attain better business-transaction response times. -
The PowerEdge portfolio
The PowerEdge family is engineered with the right combination of features and performance scalability to handle tough workloads for businesses and organizations of all sizes.
- Dell PowerEdge T20 - MT - Xeon E3-1225V3 3.2 GHz - 4 GB - HDD 1 TB
- Server - mini tower - Intel Rapid Storage Technology
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1225V3 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC
- Storage Controller
- SATA (SATA 6Gb/s / SATA 3Gb/s)
- Server Storage Bays
- Non-hot-swap 3.5"
- Hard Drive
- HDD 1 TB - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics P4600
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Black
- 17.5 cm x 43.5 cm x 36 cm
- 8.49 kg
- Limited warranty - 1 year - response time: next business day
- Server
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Black
Processor / Chipset
- CPU
- Intel Xeon E3-1225V3
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, single rank, low-voltage
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s / SATA 3Gb/s
- Channel Qty
- 4
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Integrated
- Ethernet Controller
- Intel 82579
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 3 (free) x internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x16 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCI
- 4 x USB 3.0 (2 front, 2 rear) , 6 x USB 2.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x audio line-in/microphone (1 front, 1 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x DisplayPort , 1 x VGA , 1 x serial
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Power supply
- Voltage Required
- Power Provided
- 290 Watt
Operating System / Software
- OS Provided
- 17.5 cm
- 43.5 cm
- 36 cm
- 8.49 kg
- 5 °C
- 35 °C
- 20 - 80%
