Store, share and protect. Boost collaboration in your home or small office with a quiet, compact server that helps all users get organized, share information more efficiently and become more productive.
Enhance productivity
The PowerEdge T20 server packs large internal storage capacity and capable performance into a quiet mini tower chassis designed to deliver efficient and worry-free operation. With the T20, data and applications from multiple desktops and workstations can be consolidated onto a single server to boost collaboration and productivity. -
Get organized
From work to home to the classroom, the T20 helps you improve access to information, simplify processes and helps get more done in less time. Overcome the complexity of data and applications and get organized on a central T20 server. -
Reap the benefits
Depending on your needs, you can attain greater efficiency and productivity for your home or office. -
Quiet, compact and affordable design
With its compact size and low sound levels, the T20 easily integrates into your environment and helps reduce costs. -
Secure and manageable
With or without an IT staff, the T20 makes it easy to secure your data and files.
- Dell PowerEdge T20 Mini Tower Server - MT - Xeon E3-1225V3 3.2 GHz - 4 GB - HDD 1 TB
- Server - mini tower
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1225V3 / 3.2 GHz (3.6 GHz) (Quad-Core)
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Server Storage Bays
- Non-hot-swap
- Hard Drive
- HDD 1 TB - SATA - 7200 rpm
- Networking
- GigE
- 17.5 cm x 43.6 cm x 36 cm
- Limited warranty - 1 year - response time: next business day
- Server
- Product Form Factor
- Mini tower
- 1-way
- Internal Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E3-1225V3
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Monitor
- Monitor Type
- None.
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 4 (total) / 3 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCI
- 4 x USB 3.0 , 8 x USB 2.0 , 1 x LAN (Gigabit Ethernet)
- Power supply
- Power Provided
- 290 Watt
- 17.5 cm
- 43.6 cm
- 36 cm
