Dell PowerEdge T130 Xeon E3-1220V6 1TB 8GB
Installation required? Contact us today!
Quicklinx: DSGWWS00 Mfr#: FYH48
Case Style: Mini tower
Processor Type: Xeon
Hard Disk Capacity: 2TB
Processor Speed: 3GHz, 3GHz
Installed Memory: 8GB
  • Xeon
£565.56 ex VAT
£678.67 inc VAT
The Dell PowerEdge T is an ideal server for small businesses with the right combination of value, reliability, collaboration and data protection features to improve your business continuity and productivity. The PowerEdge T was designed to meet the needs of your small business environment - customizable with your choice of hard drives for important data, RAID options for added data protection and basic systems management for easy system monitoring. The PowerEdge T provides you with the performance and features you need so you can focus on running your business.
Run applications, share information or access your data from any workstation in the office and let employees work collaboratively by moving to a server-based network. Adding a server to your business gives you the ability to connect with collaboration suites to meet and share documents or desktops over the Internet, deliver instant messages, make calls over the Internet and share desktops during conference calls - all without adding an IT staff. The PowerEdge T is ideally suited to give your business the flexibility and access you and your employees need to get more done.
  • Business value
    The PowerEdge T was designed to meet the needs of your small business environment - customizable with your choice of hard drives for important data, added data protection and basic systems management for easy system monitoring. The PowerEdge T provides you with the performance and features you need so you can focus on running your business.
  • Easy access
  • Business friendly
    Scalable, adaptable and ready to use, PowerEdge T is the ideal server for the small office setting and is poised to grow along with your business.
Dell PowerEdge T130 - MT - Xeon E3-1220V6 3 GHz - 8 GB - 2 TB
Server - mini tower
Server Scalability
1-way
1 x Intel Xeon E3-1220V6 / 3 GHz (3.5 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330)
Hard Drive
2 x 1 TB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
Video Memory
16 MB
GigE
OS Provided
No operating system
17.5 cm x 45.4 cm x 36.3 cm
11.5 kg
Pricing Type
Build To Plan (BTP)
Manufacturer Selling Program
Dell Smart Value
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM) Security Chip
Server Scalability
1-way
Internal Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, single rank
Configuration Features
1 x 8 GB
Hard Drive
HDD
2 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H330
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 8 (iDRAC8)
Bays
4 (total) / 3 (free) x internal 3.5" , 1 (total) / 0 (free) x 5.25" Slim Line
Slots
1 PCIe 3.0 x1 - full-length, full-height , 1 PCIe 3.0 x4 - full-length, full-height , 1 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x4 - half-length, full-height
2 x LAN (Gigabit Ethernet) , 5 x USB 2.0 (1 front, 4 rear) , 3 x USB 3.0 (1 front, 2 rear) , 1 x VGA , 1 x serial , 1 x management (NIC)
Pricing Type
Build To Plan (BTP)
Dell Smart Value
Power supply
Installed Qty
1
Nominal Voltage
Power Provided
290 Watt
80 PLUS Certification
80 PLUS Bronze
Operating System / Software
OS Provided
No operating system
17.5 cm
45.4 cm
36.3 cm
11.5 kg
10 °C
35 °C
10 - 80%
Brand: Dell
Price Range Ex VAT: 500 - 750
