Powerful, compact, agile. Powerful 1-socket, mini-tower first server for small office/home office and SMB to consolidate data and drive applications faster.
Business value
The PowerEdge T was designed to meet the needs of your small business environment - customizable with your choice of hard drives for important data, added data protection and basic systems management for easy system monitoring. The PowerEdge T provides you with the performance and features you need so you can focus on running your business. -
Easy access
Run applications, share information or access your data from any workstation in the office and let employees work collaboratively by moving to a server-based network. Adding a server to your business gives you the ability to connect with collaboration suites to meet and share documents or desktops over the Internet, deliver instant messages, make calls over the Internet and share desktops during conference calls - all without adding an IT staff. The PowerEdge T is ideally suited to give your business the flexibility and access you and your employees need to get more done. -
Business friendly
Scalable, adaptable and ready to use, PowerEdge T is the ideal server for the small office setting and is poised to grow along with your business.
- Dell PowerEdge T130 - MT - Xeon E3-1240V5 3.5 GHz - 8 GB - HDD 2 x 1 TB
- Server - mini tower
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1240V5 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330)
- Hard Drive
- 2 x HDD 1 TB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Black
- 17.5 cm x 45.4 cm x 36.3 cm
- 11.5 kg
- Pricing Type
- BTO
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Mini tower
- 1-way
- Internal Bays Qty
- 4
- Black
Processor / Chipset
- CPU
- Intel Xeon E3-1240V5
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 2 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Dell PERC H330
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 8 Express (iDRAC8)
- Bays
- 4 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x CPU , 1 PCIe 3.0 x1 , 2 PCIe 3.0 x4 , 1 PCIe 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
- 2 x LAN (Gigabit Ethernet) , 5 x USB 2.0 (1 front, 4 rear) , 3 x USB 3.0 (1 front, 2 rear) , 1 x VGA , 1 x serial
- Pricing Type
- BTO
- Power supply
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 290 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
Operating System / Software
- OS Provided
- 17.5 cm
- 45.4 cm
- 36.3 cm
- 11.5 kg
- 10 °C
- 35 °C
- 10 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
