Dell PowerEdge R740 Server 4114 16GB 600GB 3Y Basic NBD
Quicklinx: F33MWS00 Mfr#: F7DY6
Maximize application performance with the optimal mix of accelerator cards, storage and compute power in a platform optimized for VDI.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R740 - rack-mountable - Xeon Silver 4114 2.2 GHz - 16 GB - HDD 600 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
13.75 MB L3 Cache
Cache Per Processor
13.75 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
HDD 600 GB (hot-swap) - SAS 12Gb/s - 10000 rpm
1GbE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 75.134 cm x 8.68 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
16
Processor / Chipset
CPU
Clock Speed
2.2 GHz
Max Turbo Speed
3 GHz
Number of Cores
10-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
L3 Cache - 13.75 MB
Cache Per Processor
13.75 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
HDD - hot-swap
1 x 600 GB
Interface Type
SAS 12Gb/s
Spindle Speed
10000 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H730P
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
16 (total) / 15 (free) x hot-swap 2.5"
Slots
4 PCIe 3.0 x8
4 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear)
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
75.134 cm
8.68 cm
10 °C
35 °C
10 - 80%
F33M Dell Broadcom 5720 DP 1Gb Network Interface Card In Stock £40.09
F33M Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £188.20
