Maximize application performance with the optimal mix of accelerator cards, storage and compute power in a platform optimized for VDI.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge R740 - rack-mountable - Xeon Silver 4114 2.2 GHz - 16 GB - HDD 600 GB
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 13.75 MB L3 Cache
- Cache Per Processor
- 13.75 MB
- RAM
- 16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730P)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- HDD 600 GB (hot-swap) - SAS 12Gb/s - 10000 rpm
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 48.2 cm x 75.134 cm x 8.68 cm
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Hot-Swap Bays Qty
- 16
- Black
Processor / Chipset
- CPU
- Intel Xeon Silver 4114
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
Cache Memory
- Installed Size
- L3 Cache - 13.75 MB
- 13.75 MB
RAM
- Installed Size
- 16 GB / 1.5 TB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 600 GB
- Interface Type
- SAS 12Gb/s
- Spindle Speed
- 10000 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Dell PERC H730P
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 2 GB
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 16 (total) / 15 (free) x hot-swap 2.5"
- Slots
- 4 PCIe 3.0 x8
- 4 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear)
- Included Accessories
- Rack sliding rails, bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 48.2 cm
- 75.134 cm
- 8.68 cm
- 10 °C
- 35 °C
- 10 - 80%
