Dell PowerEdge R740 Intel Xeon Silver 411 16GB 240GB SSD
Quicklinx: F6NZWS00 Mfr#: 90ND5
Case Style: Rack-mountable
Processor Type: Xeon Silver
Hard Disk Capacity: 240GB
Processor Speed: 2.1GHz
Installed Memory: 16GB
Hurry, only 2 left in stock!
£1,325.69 ex VAT
£1,590.82 inc VAT
Maximize application performance with the optimal mix of accelerator cards, storage and compute power in a platform optimized for VDI.
  • Achieve IT transformation
    The R740 is a general-purpose workhorse optimized for workload acceleration. With its versatility, the R740 can help you transform your data center for VDI, artificial intelligence and software-defined storage.
  • Automate productivity with intelligent, embedded management
    Dell EMC automation and intelligent management mean you spend less time on routine maintenance so you can focus on bigger priorities.
Dell EMC PowerEdge R740 - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - 240 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 1.5 TB (max) DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
1 x SSD 240 GB (hot-swap)
Optical Storage
No optical drive
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 75.134 cm x 8.68 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H730P
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
4 PCIe 3.0 x8
4 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear)
Rack sliding rails, bezel, riser card
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
75.134 cm
8.68 cm
10 °C
35 °C
10 - 80%
Brand: Dell
Price Range Ex VAT: 1000 - 1500
