Dell PowerEdge R740 Intel Xeon Gold 5218 32GB 240GB SSD
Quicklinx: FL0TWS00 Mfr#: 5NYKV
Maximize your application performance with the PowerEdge R740 server, which brings you the perfect balance of accelerator cards, storage and compute resources. The R740 has the versatility to adapt to virtually any application and provides the optimum platform for VDI deployments.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R740 - rack-mountable - Xeon Gold 5218 2.3 GHz - 32 GB - SSD 240 GB
Server - rack-mountable
Bundled Services
3 Years Basic Onsite
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Gold 5218 / 2.3 GHz (3.9 GHz) (16-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
22 MB
Cache Per Processor
22 MB
RAM
32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
SSD 240 GB (hot-swap)
Optical Storage
No optical drive
Graphics Controller
Matrox G200eW3
Video Memory
16 MB
GigE, 10 GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 75.134 cm x 8.68 cm
26.3 kg
Pricing Type
Build To Plan (BTP)
Server
Bundled Services
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
22 MB
Cache Per Processor
22 MB
RAM
Installed Size
32 GB / 1.5 TB (max)
DDR4 SDRAM - ECC
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 32 GB
RAM Supported
1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Storage Controller Name
Dell PERC H730P
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eW3
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
2 x 10 Gigabit Ethernet, 2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720, Broadcom BCM57416
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
4 PCIe 3.0 x8
2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (10Gigabit Ethernet)
Rack sliding rails, bezel, riser card
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
75.134 cm
8.68 cm
26.3 kg
10 °C
35 °C
10 - 80%
