Maximize your application performance with the PowerEdge R740 server, which brings you the perfect balance of accelerator cards, storage and compute resources. The R740 has the versatility to adapt to virtually any application and provides the optimum platform for VDI deployments.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge R740 - rack-mountable - Xeon Gold 5218 2.3 GHz - 32 GB - SSD 240 GB
- Server - rack-mountable
- Bundled Services
- 3 Years Basic Onsite
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Gold 5218 / 2.3 GHz (3.9 GHz) (16-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 22 MB
- Cache Per Processor
- 22 MB
- RAM
- 32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (Dell PERC H730P)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- SSD 240 GB (hot-swap)
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eW3
- Video Memory
- 16 MB
- Networking
- GigE, 10 GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 48.2 cm x 75.134 cm x 8.68 cm
- 26.3 kg
- Pricing Type
- Build To Plan (BTP)
- Server
- Bundled Services
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon Gold 5218
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- 16-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
Cache Memory
- Installed Size
- 22 MB
- 22 MB
RAM
- Installed Size
- 32 GB / 1.5 TB (max)
- Technology
- DDR4 SDRAM - ECC
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 32 GB
- RAM Supported
- 1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- SSD - hot-swap
- Capacity
- 1 x 240 GB
Storage Controller
- 1 x RAID
- Storage Controller Name
- Dell PERC H730P
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eW3
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x 10 Gigabit Ethernet, 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720, Broadcom BCM57416
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 8 (total) / 7 (free) x hot-swap 2.5"
- Slots
- 4 PCIe 3.0 x8
- 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (10Gigabit Ethernet)
- Included Accessories
- Rack sliding rails, bezel, riser card
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 48.2 cm
- 75.134 cm
- 8.68 cm
- 26.3 kg
- 10 °C
- 35 °C
- 10 - 80%
Dell Broadcom 5720 DP 1Gb Network Interface Card | In Stock | £40.09 |
Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase | In Stock | £156.74 |
