Adapt to virtually any workload with a scalable server featuring an optimal mix of memory, storage, processing and GPUs. The incredible versatility of the PowerEdge R730 server delivers outstanding functionality in just 2U of rack space. With the combination of powerful processors, large memory, fast storage options and GPU accelerator support, the R730 performs exceptionally well in a number of demanding environments.
Deliver peak performance
Drive peak compute performance across a variety of workloads with the Intel Xeon processor E5-2600 v4 product family and state-of-the-art DDR4 memory. Boost data access for applications with 12 Gbps SAS drives and high-performance dual RAID. Take advantage of advanced accelerators and GPUs to maximize performance in HPC, VDI and imaging environments. -
Discover greater versatility
With 24 DIMMs of high-capacity, low-power DDR4 memory, seven PCI Express (PCIe) 3.0 expansion slots and highly scalable local storage, the R730 is extremely flexible. Create a dense, resource rich virtualization environment with 2.5" drives. Combine that with the R730's GPU capability to save infrastructure costs and consolidate management operations in a scalable and centralized virtual desktop environment. The GPU option also makes the R730 an excellent choice as a midrange medical imaging solution. -
Maximize operational efficiency
PowerEdge servers let you construct and manage highly efficient infrastructures for data centers and small businesses. Accelerate time-to-production with automated deployment processes that use fewer manual steps and reduce the potential for error. Improve IT productivity with innovative at-the-server management tools like iDRAC Direct and iDRAC Quick Sync to deliver in-depth system health status and speed deployment, optimize data center energy usage with improved performance-per-watt and more granular control of power and cooling. -
Innovative management with intelligent automation
The Dell OpenManage systems management portfolio includes innovative solutions that simplify and automate essential server lifecycle management tasks - making IT operations more efficient and Dell EMC servers the most productive, reliable and cost effective. Leveraging the incomparable agent-free capabilities of the PowerEdge embedded integrated Dell Remote Access Controller (iDRAC) with Lifecycle Controller technology, server deployment, configuration and updates are streamlined across the OpenManage portfolio and through integration with third-party management solutions.
- Dell PowerEdge R730 - rack-mountable - Xeon E5-2650V3 2.3 GHz - 32 GB - HDD 300 GB
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 2 x Intel Xeon E5-2650V3 / 2.3 GHz (, up to 3 GHz, (10-core)
- Processor Socket
- FCLGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 50 MB
- Cache Per Processor
- 25 MB
- RAM
- 32 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SAS 12Gb/s) (Dell PERC H730)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- HDD 300 GB (hot-swap)
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- OS Provided
- No operating system
- 48.2 cm x 75.58 cm x 8.73 cm
- 18.9 kg
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon E5-2650V3
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 50 MB
- 25 MB
RAM
- Installed Size
- 32 GB / 768 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total)
- Registered
- RAM Supported
- 768 GB registered - ECC , 3 TB Load-Reduced - ECC
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 300 GB
Storage Controller
- 1 x RAID - internal
- Controller Interface Type
- SAS 12Gb/s
- Storage Controller Name
- Dell PERC H730
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Integrated
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 8 Express (iDRAC8)
- Bays
- 8 (total) / 7 (free) x hot-swap 2.5"
- Slots
- 3 PCIe 3.0 x16 - low-profile (x8 mode) , 2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height (x8 mode)
- 2 x USB 3.0 , 2 x VGA (1 front, 1 rear) , 1 x USB 2.0 , 1 x serial , 4 x LAN (Gigabit Ethernet)
- Included Accessories
- Bezel
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 48.2 cm
- 75.58 cm
- 8.73 cm
- 18.9 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
