Dell PowerEdge R640 Serverlver 4114 16GB 600GB 3Y Basic NBD
Quicklinx: F33KWS00 Mfr#: W6J4H
Case Style: Rack-mountable
Processor Type: Xeon Silver
Hard Disk Capacity: 600GB
Processor Speed: 2.2GHz
Installed Memory: 16GB
Hurry, only 2 left in stock!
£1,634.62 ex VAT
£1,961.54 inc VAT
The PowerEdge R640 is the ideal dual-socket! 1U platform for dense scale-out data center computing. The R640 combines density, performance and scalability to optimize application performance and data center density.
  • Maximize application performance and density
    The scalable business architecture of the R640 is created to maximize application performance and provide the flexibility to optimize configurations based on the application and use case. With the R640 you can create an NVMe cache pool and use either 2.5" or 3.5" drives for data storage. Combined with up to 24 DIMM's, 12 of which can be NVDIMM's, you have the resources to create the optimum configuration to maximize application performance with the optimum configuration in only a 1U chassis.
  • Automate maintenance with Dell EMC OpenManage
    The Dell EMC OpenManage portfolio helps deliver peak efficiency for PowerEdge servers, delivering intelligent, automated management of routine tasks. Combined with unique agent-free management capabilities, the R640 is simply managed, freeing up time for high profile projects. Simplify management with the OpenManage Enterprise console, with customized reporting and automatic discovery. Take advantage of QuickSync capabilities and gain access to your servers easily through your phone or tablet.
  • Guard your data center with built in security
    Every PowerEdge server is created as part of a cyber-resilient architecture, integrating security into the full server lifecycle. The R640 leverages security features built-into every PowerEdge server strengthening protection so you can reliably and securely deliver accurate data to your customers no matter where they are. By considering each aspect of system security, from design to retirement, Dell EMC ensures trust and delivers a worry-free, secure infrastructure without compromise. Maintain data safety with cryptographically signed firmware packages and Secure Boot. Prevent unauthorized or malicious change with Server Lockdown. Wipe all data from storage media including hard drives, SSDs and system memory quickly and securely with System Erase.
Dell EMC PowerEdge R640 - rack-mountable - Xeon Silver 4114 2.2 GHz - 16 GB - 600 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon Silver 4114 / 2.2 GHz (3 GHz) (10-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
13.75 MB
Cache Per Processor
13.75 MB
RAM
16 GB (installed) / 1536 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
1 x 600 GB (hot-swap) - SAS - 10000 rpm
Optical Storage
No optical drive
GigE, 10 GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 80.851 cm x 4.28 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
10-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
13.75 MB
Cache Per Processor
13.75 MB
RAM
Installed Size
16 GB / 1536 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
1536 GB Load-Reduced - ECC , 768 GB registered - ECC
Hard Drive
HDD - hot-swap
1 x 600 GB
Interface Type
SAS
Spindle Speed
10000 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H730P
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x 10 Gigabit Ethernet, 2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720, Broadcom BCM57416
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
2 PCIe 3.0 x16 - half-length, low-profile
2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A (1 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (10Gigabit Ethernet)
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
80.851 cm
4.28 cm
10 °C
35 °C
10 - 80%
Brand: Dell
Price Range Ex VAT: 1500+
