Dell PowerEdge R630 Xeon,E5-2620 v4,16GB,300GB,DVD RW, No OS
Quicklinx: C970WS00 Mfr#: R630-0725
  • Xeon
Maximize data center efficiency with an ultra-dense virtualization or database engine that supports up to 24 flash SSDs in a 1U chassis.
The R630 features the flexible storage capacity and high-density processing that is crucial to superior IO performance in Exchange and SharePoint applications.
The R630 can be easily configured as a reliable, general-purpose server for business-critical applications, with automated management and high-availability features, such as redundant power supply units (PSUs); hot-plug and swappable PSUs, HDDs and fans; dual SD card option for failsafe hypervisors.
With high-performance processing, large memory capacity and innovative local storage options offering greater scalability throughout the portfolio, the latest generation of PowerEdge servers meets your needs today, with the hardware, headroom and simplified management to adapt as your workloads demand.
  • Deliver peak performance
    Build a blazingly fast transactional database with the R630 24 all-flash drive configuration. Combine the density, scalability and performance of 1.8" SSDs with dual-PERC capability to deliver a superior solution that can boost performance by storing an entire database. When combined with the SanDisk DAS Cache solution, the R630 can help increase OLTP transactions and concurrent usage for latency-sensitive applications, such as e-commerce or financial trading.
  • Discover greater versatility
    With DIMMs of memory, and configured with 2.5" drives, the R630 can provide a dense, resource-rich midsize virtualization environment to drive business intelligence applications, from customer relationship management (CRM) to enterprise resource planning (ERP), while it saves on space, energy and capital costs.
  • Maximize operational efficiency
    Quickly and securely monitor or modify critical server settings "at the box" with the iDRAC Quick Sync bezel with embedded near field communication (NFC) capability. Use a handheld device with the bezel to quickly check system health details, and use iDRAC Direct to easily deploy or modify settings across multiple servers with a USB key or laptop, eliminating the potential for configuration errors.
  • Innovative management with intelligent automation
    The Dell OpenManage systems management portfolio includes innovative solutions that simplify and automate essential server lifecycle management tasks - making IT operations more efficient and Dell EMC servers the most productive, reliable and cost effective. Leveraging the incomparable agent-free capabilities of the embedded integrated Dell Remote Access Controller (IDRAC) with Lifecycle Controller technology, server deployment, configuration and updates are streamlined across the OpenManage portfolio and through integration with third-party management solutions.
Dell PowerEdge R630 - rack-mountable - Xeon E5-2620V4 2.1 GHz - 16 GB - HDD 300 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
16 GB (installed) / 768 GB (max) - DDR4 SDRAM
Storage Controller
RAID (SAS 12Gb/s) (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
HDD 300 GB - SAS - 10000 rpm
Optical Storage
DVD-Writer
GigE
OS Provided
No operating system
48.23 cm x 70.05 cm x 4.28 cm
Pricing Type
BTO
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
16 GB / 768 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
Hard Drive
HDD
1 x 300 GB
Interface Type
SAS
Spindle Speed
10000 rpm
Storage Controller
1 x RAID
Controller Interface Type
SAS 12Gb/s
Storage Controller Name
Dell PERC H730P
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 8 (iDRAC8)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 3 PCIe 3.0
4 x LAN (Gigabit Ethernet)
Bezel
Pricing Type
BTO
Power supply
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.23 cm
70.05 cm
4.28 cm
