Maximize data center efficiency with an ultra-dense virtualization or database engine that supports up to 24 flash SSDs in a 1U chassis.
The R630 features the flexible storage capacity and high-density processing that is crucial to superior IO performance in Exchange and SharePoint applications.
The R630 can be easily configured as a reliable, general-purpose server for business-critical applications, with automated management and high-availability features, such as redundant power supply units (PSUs); hot-plug and swappable PSUs, HDDs and fans; dual SD card option for failsafe hypervisors.
With high-performance processing, large memory capacity and innovative local storage options offering greater scalability throughout the portfolio, the latest generation of PowerEdge servers meets your needs today, with the hardware, headroom and simplified management to adapt as your workloads demand.
Deliver peak performance
Build a blazingly fast transactional database with the R630 24 all-flash drive configuration. Combine the density, scalability and performance of 1.8" SSDs with dual-PERC capability to deliver a superior solution that can boost performance by storing an entire database. When combined with the SanDisk DAS Cache solution, the R630 can help increase OLTP transactions and concurrent usage for latency-sensitive applications, such as e-commerce or financial trading. -
Discover greater versatility
With DIMMs of memory, and configured with 2.5" drives, the R630 can provide a dense, resource-rich midsize virtualization environment to drive business intelligence applications, from customer relationship management (CRM) to enterprise resource planning (ERP), while it saves on space, energy and capital costs. -
Maximize operational efficiency
Quickly and securely monitor or modify critical server settings "at the box" with the iDRAC Quick Sync bezel with embedded near field communication (NFC) capability. Use a handheld device with the bezel to quickly check system health details, and use iDRAC Direct to easily deploy or modify settings across multiple servers with a USB key or laptop, eliminating the potential for configuration errors. -
Innovative management with intelligent automation
The Dell OpenManage systems management portfolio includes innovative solutions that simplify and automate essential server lifecycle management tasks - making IT operations more efficient and Dell EMC servers the most productive, reliable and cost effective. Leveraging the incomparable agent-free capabilities of the embedded integrated Dell Remote Access Controller (IDRAC) with Lifecycle Controller technology, server deployment, configuration and updates are streamlined across the OpenManage portfolio and through integration with third-party management solutions.
- Dell PowerEdge R630 - rack-mountable - Xeon E5-2620V4 2.1 GHz - 16 GB - HDD 300 GB
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 768 GB (max) - DDR4 SDRAM
- Storage Controller
- RAID (SAS 12Gb/s) (Dell PERC H730P)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- HDD 300 GB - SAS - 10000 rpm
- Optical Storage
- DVD-Writer
- Networking
- GigE
- OS Provided
- No operating system
- Black
- 48.23 cm x 70.05 cm x 4.28 cm
- Pricing Type
- BTO
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 16 GB / 768 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 16 GB
Hard Drive
- HDD
- Capacity
- 1 x 300 GB
- Interface Type
- SAS
- Spindle Speed
- 10000 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SAS 12Gb/s
- Storage Controller Name
- Dell PERC H730P
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50, RAID 60
- Buffer Size
- 2 GB
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 8 (iDRAC8)
- Bays
- 8 (total) / 7 (free) x hot-swap 2.5"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 3 PCIe 3.0
- 4 x LAN (Gigabit Ethernet)
- Included Accessories
- Bezel
- Pricing Type
- BTO
- Power supply
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 48.23 cm
- 70.05 cm
- 4.28 cm
