Dell PowerEdge R540 Server Xeon Silver 4110 16GB 1TB 3Y Basic NBD
Quicklinx: F33HWS00 Mfr#: KGC96
Case Style: Rack-mountable
Processor Type: Xeon Silver
Hard Disk Capacity: 1TB
Processor Speed: 2.1GHz
Installed Memory: 16GB
£1,199.20 ex VAT
£1,439.04 inc VAT
The PowerEdge R540 delivers the ideal balance of resources and affordability to adapt to a variety of application demands.
  • Power your applications with the versatility of the R540
    The PowerEdge R540 delivers the versatility and flexibility to power a variety of applications. With a balanced set of resources, expandability and affordability the R540 adapts to the demands of the modern data center with the ideal value optimized design.
  • Intuitive systems management with intelligent automation
    Dell EMC PowerEdge servers are optimized for top efficiency and uptime, with intelligent automation that decreases time spent on common IT tasks.
  • Rely on PowerEdge with built-in security
    Every PowerEdge server is made with a cyber-resilient architecture, building security into all parts of a server's life cycle. The R540 uses these security features so you can reliably and securely deliver the right data to where your customers are, no matter where they are.
Dell EMC PowerEdge R540 - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - 1 TB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 512 GB (max) DDR4 SDRAM - ECC
Storage Controller
RAID (SAS 12Gb/s) (Dell PERC H730P+)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
1 x 1 TB (hot-swap) - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 68.1755 cm x 8.68 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Status LCD
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 512 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
512 GB registered - ECC , 1 TB Load-Reduced - ECC
Hard Drive
HDD - hot-swap
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SAS 12Gb/s
Storage Controller Name
Dell PERC H730P+
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Express (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 3.5"
Slots
2 PCIe 3.0 x16
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 - Type A (2 in front) , 1 x management (NIC) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x serial , 2 x USB 3.0 - Type A (2 rear) , 2 x VGA (1 front, 1 rear)
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
68.1755 cm
8.68 cm
10 °C
35 °C
10 - 80%
Brand: Dell
Price Range Ex VAT: 1000 - 1500
