Dell PowerEdge R540 Intel Xeon Silver 411 16GB 240GB SSD
Quicklinx: F6NBWS00 Mfr#: 1KX77
The PowerEdge R540 delivers the ideal balance of resources and affordability to adapt to a variety of application demands.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R540 - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - SSD 240 GB - with 3-year ProSupport
Server - rack-mountable
Bundled Services
3 Years ProSupport
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SAS 12Gb/s) (Dell PERC H730P+)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
SSD 240 GB (hot-swap)
Optical Storage
No optical drive
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 68.1755 cm x 8.68 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years
Server
Bundled Services
3 Years ProSupport
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Status LCD
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 512 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
512 GB registered - ECC , 1 TB Load-Reduced - ECC
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Controller Interface Type
SAS 12Gb/s
Storage Controller Name
Dell PERC H730P+
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Express (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 3.5"
Slots
2 PCIe 3.0 x16 - low-profile
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 - Type A (2 in front) , 1 x management (NIC) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x serial , 2 x USB 3.0 - Type A (2 rear) , 2 x VGA (1 front, 1 rear)
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
68.1755 cm
8.68 cm
10 °C
35 °C
10 - 80%
F6NB Dell Broadcom 5720 DP 1Gb Network Interface Card In Stock £40.09
F6NB Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £188.20
