Dell PowerEdge R440 Server Xeon Silver 4110 16GB 600GB 3Y Bas NBD
Quicklinx: F33GWS00 Mfr#: K01YM
The PowerEdge R440 delivers the perfect combination of performance and density for HPC and web-tech deployments with a feature set right-sized for scale-out infrastructure environments.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R440 - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - HDD 600 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330+)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
HDD 600 GB (hot-swap) - SAS - 10000 rpm
Optical Storage
No optical drive
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm 4.28 cm
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Status LCD
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 512 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
512 GB registered - ECC , 1 TB Load-Reduced - ECC
Hard Drive
HDD - hot-swap
1 x 600 GB
Interface Type
SAS
Spindle Speed
10000 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H330+
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 - Type A (1 in front) , 2 x VGA (1 front, 1 rear) , 1 x USB 2.0 - micro-USB (1 in front) , 2 x USB 3.0 - Type A , 1 x serial
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
550 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
4.28 cm
10 °C
35 °C
10 - 80%
F33G Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £188.20
