Dell PowerEdge R440 Intel Xeon Bronze 3204 16GB 240GB SSD
Quicklinx: FL0BWS00 Mfr#: HF50K
The PowerEdge R440 delivers the perfect combination of performance and density for HPC and web-tech deployments with a feature set right-sized for scale-out infrastructure environments.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R440 - rack-mountable - Xeon Silver 4208 2.1 GHz - 16 GB - SSD 240 GB - no RAID
Server - rack-mountable
Bundled Services
3 Years Basic Onsite
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon Silver 4208 / 2.1 GHz (3.2 GHz) (8-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
11 MB
Cache Per Processor
11 MB
RAM
16 GB (installed) / 512 GB (max) - DDR4 SDRAM
Storage Controller
RAID (Dell PERC H330)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
SSD 240 GB (hot-swap)
Optical Storage
No optical drive
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 67.769 cm x 4.28 cm
Pricing Type
Build To Plan (BTP)
Server
Bundled Services
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 512 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
512 GB registered , 1 TB Load-Reduced
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
RAID
Storage Controller Name
Dell PERC H330
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
1 PCIe x16
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 (1 in front) , 2 x VGA (1 front, 1 rear) , 1 x USB 2.0 - micro-USB (1 in front) , 2 x USB 3.0 , 1 x serial
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
550 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
67.769 cm
4.28 cm
10 °C
35 °C
10 - 80%
FL0B Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £188.20
