Dell PowerEdge R340 Intel Xeon E-2134 16GB 1TB
Quicklinx: F6NNWS00 Mfr#: 6WDJR
  • Xeon
The Dell EMC PowerEdge R340 is a single-socket 1U rack server designed for productivity and data intensive applications for remote office/branch offices.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R340 - rack-mountable - Xeon E-2134 3.5 GHz - 16 GB - HDD 1 TB
Server - rack-mountable
Bundled Services
3 Years Basic Onsite
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E-2134 / 3.5 GHz (4.5 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
HDD 1 TB (hot-swap) - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Matrox G200
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm 4.28 cm
Pricing Type
Build To Plan (BTP)
Server
Bundled Services
Product Form Factor
Rack-mountable - 1U
Server Scalability
1-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Intel Xeon E-2134
Clock Speed
3.5 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
HDD - hot-swap
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H330
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Express (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 2.5"
Slots
1 PCIe 3.0 x8 , 1 PCIe 3.0 x4
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 - Type A (1 in front) , 1 x VGA , 1 x USB 2.0 - micro-USB (1 in front) , 2 x USB 3.0 - Type A , 1 x serial
Rack sliding rails, bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
350 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
4.28 cm
10 °C
35 °C
10 - 80%
