Dell PowerConnect W-IAP214 Radio Access Point 802.11a/b/g/n
Quicklinx: BTTTWS00 Mfr#: 210-ADHR
  • IEEE 802.11n
Cost-effective, enterprise-class WiFi networking for a variety of environments. Easy to deploy, use and maintain.
  • Deploy with ease
    Be up and running in minutes, provisioning your W-Series Instant Access Points (IAPs) in a few easy steps using virtually any laptop's wireless connection. W-Series IAPs are designed to provide enterprise-class networking services without enterprise-size complexity and include an expanded wired + wireless IAP portfolio with high-end wireless features for hotspots and remote branches.
  • Protect your investment
    As WLAN requirements grow, configuration settings can be used to easily convert the W-Series IAPs to campus APs that work with a centralized-controller architecture.
  • Enterprise-grade Wi-Fi network
    Combine enterprise capabilities with entry-level simplicity using Wi-Fi network through W-Series IAPs with built-in virtual controllers. When multiple IAPs are connected, a single IAP acts as a primary virtual controller. If that controller fails, another W-Series IAP in the chain automatically takes over as the primary virtual controller without disrupting services. To expand your network, just add more W-Series IAPs. Configuration is automatically uploaded from the primary virtual controller.
  • Wired + wireless instant or remote AP
    Several W-Series IAP models provide both wired and wireless connectivity, ideal for small branches or teleworkers. The wired connectivity includes additional Ethernet ports to connect wired devices as well as a USB port to connect a 3G/4G modem for internet connectivity.
  • Confidently manage your Wi-Fi networks
    Securely manage and administer a W-Series IAP Wi-Fi network from a single built-in web-based GUI.
  • Enhance RF management
    Build wireless networks that adjust to how Wi-Fi clients interact. W-Series IAPs with Dell Adaptive Radio Management (ARM) technology help ensure that data, voice and video applications have sufficient network resources to operate properly, allowing maximum client performance while enhancing stability and predictability of the entire Wi-Fi network.
Dell PowerConnect W-IAP214 - radio access point - Wi-Fi 5
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
18 cm x 18 cm x 4.5 cm
610 g
Radio access point
Ruggedized Design
Indoor
18 cm
18 cm
4.5 cm
610 g
External
Wireless
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, system, WLAN, LAN
Auto-sensing per device, load balancing, auto-uplink (auto MDI/MDI-X), Wireless Intrusion Detection System (WIDS), IPSec Virtual Private Network (VPN), Trusted Platform Module (TPM), reset button, Adaptive Radio Management (ARM), 3T3R MIMO technology, Energy Efficient Ethernet
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.3ac, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 1 x USB 2.0 - Type A
EN 60950, IEC 60950, UL 60950, CB, Directive 1999/5/EC, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 60601-1, Directive 2006/95/EC, EN 300 328, EN 301 489
PoE+
OS Provided
ArubaOS
Limited warranty - parts - lifetime
50 °C
5 - 95% (non-condensing)
