The multifunctional Dell Networking W-series IAP 109 Remote Access Point delivers secure 802.11n wireless and wired networking, and access to corporate resources from branch and home offices.
With unmatched deployment flexibility, the W-IAP 109 series can operate in Instant mode or in controller-managed mode where all network services are centralized by Dell mobility controllers.
In Instant mode, traffic is locally bridged but it still provides the flexibility of secure tunneling to mobility controllers. The W-IAP 109 offers a wide range of enterprise-class features, including role-based network access, policy-based forwarding, and adaptive radio management (ARM), which optimizes Wi-Fi client performance and ensures that Dell W-series APs stay clear of interference.
At locations that require greater coverage, the W-IAP 109 can join an Instant WLAN cluster. Simply install additional W-series IAP's and the entire cluster is managed as one. If one W-series Instant AP fails, another AP automatically takes over with no disruption.
With dual-radios and wireless data rate up to 300 Mbps in the 2.4-GHz and 5-GHz radio bands, the W-IAP109 delivers high performance 11n wireless capacity and coverage. In addition, the W-IAP109 provides one 10/100/1000BASE-T Ethernet uplink, one 10/100BASE-T local Ethernet port and one USB port to connect to 3G and 4G networks.
- Dell PowerConnect W-IAP109 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - indoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE+
- 16 cm x 4.3 cm x 16 cm
- 300 g
- Limited lifetime warranty
- Ruggedized Design
- Indoor
- 16 cm
- 4.3 cm
- 16 cm
- 300 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
- Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Trusted Platform Module (TPM), 2T2R MIMO technology, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 1 x USB 2.0 - Type A
- EN 60950, IEC 60950, CB, FCC, EN 60601-1-2, cTUVus, Directive 72/23/EEC, EN 300 328, EN 301 489, EN 301 893
- PoE+
- 12.5 Watt
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
