Your basket is empty
Dell PowerConnect W-7030 8 port 10Mb LAN, 100Mb LAN GigE
Quicklinx: BVY3WS00 Mfr#: 210-ADEP
Deploy wireless networks that adjust to how Wi-Fi clients interact. Dell's Adaptive Radio Management technology built into W-Series controllers helps ensure maximum client performance while enhancing stability and predictability of the entire Wi-Fi network.
Certified for Microsoft Lync, the Dell W-Series controllers and access points (APs) offer high-performance, secure and reliable wireless access and management across indoor, outdoor and remote locations. W-Series controllers and access points are ideal for organizations seeking to enforce policies and security from a central location and encrypt data from the AP all the way back to the data center, which can also serve as a termination point for your virtual private network (VPN). Dell W-Series controllers can be easily installed without disrupting your existing wired network.
W-Series 7200 Controllers feature high density and extended capabilities for large enterprise Wi-Fi LANs. They recognize new cloud-based and mobile applications and provide visibility for IT to prioritize mobile apps by user.
Dell PowerConnect W-7030 - network management device
Network management device
Rack-mountable - 1U
Ports Qty
8
Performance
Firewall throughput: 8 Gbps , 3DES throughput: 2.4 Gbps , AES throughput: 4.4 Gbps
Maximum number of access points: 64 , Maximum number of access points (remote): 64 , Active firewall sessions: 65536 , Virtual interfaces (VLANs): 4094 , Concurrent IPSec sessions: 2048 , Maximum number of users: 4096
30.5 cm x 21.1 cm x 4.4 cm
1 year warranty
Height (Rack Units)
1U
Built-in Devices
Status LCD
30.5 cm
21.1 cm
4.4 cm
Rack-mountable
Ports Qty
8
Performance
802.1x authentication
Encryption Algorithm
DES, Triple DES, TKIP, WPA, WPA2, AES-CCMP, AES-CCM, WPA2-PSK, AES-CBC, WEP
1 x USB , 8 x 1000Base-T - RJ-45 , 8 x - SFP (mini-GBIC)
55 Watt
Limited warranty - parts - 1 year
BVY3 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
BVY3 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
BVY3 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
BVY3 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
