The Dell Power Companion lets you bring extra power with you, so you can be more productive. This handy device powers notebooks, as well smartphones, tablets or other USB-enabled devices. The Dell Power Companion is lightweight and compact, so you can stay powered on-the-go without adding bulk to your bag.
Designed to charge devices during storage
This compact power solution fits seamlessly into your mobile lifestyle by fitting neatly into your laptop case or bag. The Dell Power Companion is designed to deliver in-bag charging, so your devices are charged when you need them. -
USB charging to power additional devices
The Dell Power Companion helps keep all your mobile devices charged and ready to go, including smartphones, tablets and more. Two USB charging ports let you simultaneously charge a pair of mobile devices in addition to your notebook. -
Powerful battery provides reliable backup power
The compact and convenient Dell Power Companion features a powerful battery that provides reliable power when you're on the go and is easily charged. A five-segment LED clearly displays how much power is left, so you can plan accordingly.
- Dell Power Companion - power bank - 12000 mAh
- Power bank
- Output connectors
- 2 x 4 pin USB Type A , 2 x power
- Battery
- - 12000 mAh
- Battery Form Factor
- External
- Batteries Qty
- 1
- Designed For
- Alienware M11; Inspiron 13 73XX, 14 34XX, 15 75XX, 15 N5030, 15 N5040, 15 N5050, 17 7778, 3552, 5458, 55XX, 57XX, 7359, 75XX; Latitude 13 7350, 3150, 33XX, 34XX, 35XX, 5480, E5270, E5470, E5550, E5570, E7270, E7450, E7470; Venue 10, 10 5050, 10 7040, 8; Vostro 35XX, 5459; XPS 13, 13 9350, 15 95XX
- Power bank
- Battery Enclosure Type
- External
- Power Output Connectors Details
- Quantity
- 1
- Capacity
- 12000 mAh
- Cables Included
- 2 x charging cable
- Designed For
- Alienware M11x R3, M11xR2 , Dell Inspiron 11z, 13 7347, 13 7348, 13 7353, 14 3421, 14 3442, 14 3451, 14 5447, 14 7437, 1464, 1470, 15 3551, 15 5547, 15 7548, 15 7558, 15 N5030, 15 N5040, 15 N5050, 1546, 1564, 1570, 15R 5537, 17 7778 2-in-1, 1750, 1764, 3552, 5458, 5545, 5552, 5555, 5558, 5559, 5758, 5759, 7359, 7559, 7568, M5030, N3010, N4010, N4020, N4030, N7010, N7110 , Dell Latitude 12 Rugged Extreme (7204), 13 7350, 14 Rugged (5404), 14 Rugged Extreme (7404), 3150, 3340, 3350, 3440, 3450, 3460, 3470, 3540, 3550, 3560, 3570, 5480, E5250, E5270, E5440, E5450, E5470, E5540, E5550, E5570, E6440, E6540, E7240, E7250, E7270, E7440, E7450, E7470 , Dell Studio 1457, 1458, 1557, 1558, 1745, 1747, 1749, XPS 1645, XPS 1647 , Dell Venue 10 5050, 10 7040, 10 Pro (5050), 10 Pro (5055), 10 Pro (5056), 11 Pro (5130), 11 Pro (7130), 11 Pro (7139), 11 Pro (7140), 8 3840, 8 7840, 8 Pro (3845), 8 Pro (5855) , Dell Vostro 1440, 1540, 2420, 2520, 3300, 3400, 3450, 3460, 3500, 3550, 3558, 3559, 3560, 3700, 3750, 5459 , Dell XPS 13, 13 (9343), 13 9350, 14 (L401X), 14 (L421X), 15 (L502X), 15 9550, 15 9570
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
