Product
Dell Power Companion External Battery Pack for Inspiron
Quicklinx: BGH6WS00 Mfr#: 451-BBME
The Dell Power Companion lets you bring extra power with you, so you can be more productive. This handy device powers notebooks, as well smartphones, tablets or other USB-enabled devices. The Dell Power Companion is lightweight and compact, so you can stay powered on-the-go without adding bulk to your bag.
  • Designed to charge devices during storage
    This compact power solution fits seamlessly into your mobile lifestyle by fitting neatly into your laptop case or bag. The Dell Power Companion is designed to deliver in-bag charging, so your devices are charged when you need them.
  • USB charging to power additional devices
    The Dell Power Companion helps keep all your mobile devices charged and ready to go, including smartphones, tablets and more. Two USB charging ports let you simultaneously charge a pair of mobile devices in addition to your notebook.
  • Powerful battery provides reliable backup power
    The compact and convenient Dell Power Companion features a powerful battery that provides reliable power when you're on the go and is easily charged. A five-segment LED clearly displays how much power is left, so you can plan accordingly.
Dell Power Companion - external battery pack - 12000 mAh
External battery pack
Output connectors
2 x 4 pin USB Type A , 2 x power
- 12000 mAh
Battery Form Factor
External
Batteries Qty
1
Inspiron 13 73XX, 14 3451, 14 7437, 15 3551, 15 7548, 17 7778, 5458, 55XX, 57XX; Latitude 12, 13 7350, 14, 3350, 3450, 3550, 5480, E5250, E5270, E5440, E5450, E5540, E5550, E7240, E7250, E7270, E7440, E7450, E7470; Venue 10, 8, 8 3840, 8 7840; Vostro 35XX, 5459; XPS 13, 13 9350, 15 9550
Battery Enclosure Type
External
Quantity
1
12000 mAh
2 x charging cable
Dell Inspiron 13 7347, 13 7348, 14 3451, 14 7437, 15 3551, 15 7548, 17 7778 2-in-1, 5458, 5555, 5558, 5559, 5758, 5759 , Dell Latitude 12 Rugged Extreme (7204), 13 7350, 14 Rugged (5404), 14 Rugged Extreme (7404), 3350, 3450, 3550, 5480, E5250, E5270, E5440, E5450, E5540, E5550, E7240, E7250, E7270, E7440, E7450, E7470 , Dell Venue 10 Pro (5050), 10 Pro (5055), 8 3840, 8 7840, 8 Pro (3845) , Dell Vostro 3558, 3559, 5459 , Dell XPS 13, 13 (9343), 13 9350, 15 9550
BGH6 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.89
BGH6 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.46
BGH6 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
BGH6 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.54
BGH6 C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.01
BGH6 C2G USB Superbooster Extender Kit In Stock £37.35
BGH6 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.11
BGH6 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
