Dell Power Companion (18000 mAh)-PW7015L
Quicklinx: CKWSWS00 Mfr#: 451-BBMV
30 in stock
£88.68 ex VAT
£106.41 inc VAT
The Dell Power Companion lets you bring extra power with you, so you can be more productive. This handy device powers select Dell Notebooks and Ultrabooks, as well as up to two smartphones, tablets or other USB-enabled devices. It features 18,000 mAh 6 cell battery that provides reliable power when you're on the go and is easily charged using your Dell power adapter. Moreover, it is lightweight and compact, so you can stay powered on-the-go without adding bulk to your bag. With all this features and more the two USB charging ports let you simultaneously charge a pair of mobile devices in addition to your Dell notebook.
  • Portable power for Dell Ultrabooks, notebooks and tablets
    The Dell Power Companion lets you bring extra power with you, so you can be more productive. This handy device powers select Dell Notebooks and Ultrabooks, as well as up to two smartphones, tablets or other USB-enabled devices. The Dell Power Companion is lightweight and compact, so you can stay powered on-the-go without adding bulk to your bag.
  • Designed to charge devices during storage
    This compact power solution fits seamlessly into your mobile lifestyle by fitting neatly into your laptop case or bag. The Dell Power Companion is designed to deliver in-bag charging, so your devices are charged when you need them. It's also specifically designed to fit into the Dell Premier Backpack and Dell Premier Briefcases.
  • USB charging to power additional devices
    The Dell Power Companion helps keep all your mobile devices charged and ready to go, including smartphones, tablets and more. Two USB charging ports let you simultaneously charge a pair of mobile devices in addition to your Dell notebook.
  • 18,000 mAh battery provides reliable, powerful backup power
    The compact and convenient Dell Power Companion features an 18,000 mAh 6 cell battery that provides reliable power when you're on the go and is easily charged using your Dell power adapter. A five-segment LED clearly displays how much power is left, so you can plan accordingly.
Dell Notebook Power Bank Plus (Barrel) PW7015L - external battery pack - Li-Ion - 18000 mAh
External battery pack
417 g
Output connectors
2 x 4 pin USB Type A
Lithium Ion - 18000 mAh
Battery Form Factor
External
7.8 cm x 16.2 cm x 2.15 cm
Inspiron 3195 2-in-1, 35XX, 37XX, 53XX, 55XX, 57XX, 7306 2-in-1, 73XX, 7591 2, 75XX, 75XX 2-in-1, 7791 2-in-1; Latitude 33XX, 34XX, 35XX, 5310, 5310 2-in-1, 54XX; Precision Mobile Workstation 35XX, 5540; Vostro 13 5310, 14 5410, 15 5510, 34XX, 35XX, 53XX, 54XX, 55XX; XPS 13 9350, 15 7590, 15 95XX
Battery Enclosure Type
External
Lithium Ion
18000 mAh
2 x charging cable - external
7.8 cm
16.2 cm
2.15 cm
417 g
Alienware M11x R3, M11xR2 , Dell Inspiron 11z, 13 7347, 13 7348, 13 7353, 14 3421, 14 3442, 14 3451, 14 5447, 1464, 1470, 15 3551, 15 5547, 15 5579 2-in-1, 15 7558, 15 N5030, 15 N5040, 15 N5050, 1546, 1564, 1570, 15R 5537, 17 7773 2-in-1, 17 7778 2-in-1, 1750, 1764, 3195 2-in-1, 3552, 3593, 3780, 3793, 5370, 5391, 5458, 5502, 5545, 5552, 5555, 5558, 5559, 5570, 5575, 5580, 5593, 5758, 5759, 5770, 5775, 7306 2-in-1, 7359, 7370, 7380, 7559, 7568, 7570, 7573 2-in-1, 7580, 7586 2-in-1, 7591 2 in 1, 7791 2-in-1, M5030, N3010, N4010, N4020, N4030, N7010, N7110 , Dell Latitude 12 Rugged Extreme (7204), 13 7350, 14 Rugged (5404), 14 Rugged Extreme (7404), 3150, 3160, 3320, 3340, 3350, 3420, 3440, 3450, 3460, 3470, 3480, 3510, 3520, 3540, 3550, 3560, 3570, 3580, 5290 2-in-1, 5310, 5310 2-in-1, 5414 Rugged, 5480, 5491, 5580, 7214 Rugged Extreme, 7290, 7390, 7390 2-in-1, 7490, E5250, E5270, E5440, E5450, E5470, E5540, E5550, E5570, E6440, E6540, E7240, E7250, E7270, E7440, E7450, E7470 , Dell Precision Mobile Workstation 3550, 3551, 5540, M4800, M6800 , Dell Studio 1457, 1458, 1557, 1558, 1745, 1747, 1749, XPS 1645, XPS 1647 , Dell Venue 10 5050, 10 7040, 10 Pro (5050), 10 Pro (5055), 10 Pro (5056), 11 Pro (5130), 11 Pro (7130), 11 Pro (7139), 11 Pro (7140), 8 3840, 8 7840, 8 Pro (3845), 8 Pro (5855) , Dell Vostro 13 5310, 14 5410, 1440, 15 5510, 1540, 2420, 2520, 3300, 3400, 3450, 3460, 3480, 3481, 3490, 3491, 3500, 3501, 3550, 3558, 3559, 3560, 3578, 3590, 3591, 3700, 3750, 5301, 5370, 5390, 5391, 5415, 5459, 5471, 5502, 5515 , Dell XPS 13 (9343), 13 9350, 14 (L401X), 14 (L421X), 15 (L502X), 15 7590, 15 9550, 15 9560, 15 9570
Brand: Dell
Stock Status: In stock
