Your basket is empty
Dell Power Adapter 90 Watt
Quicklinx: 9763WS00 Mfr#: YY20N
  • We’ve redesigned our adapters from wall to cable, so you can enjoy a more comfortable and consistent experience in everything you do.
  • Provides 90-Watt of power to charge your system
  • Neatly wrapped 3 ft power cord fits snugly around the adapter for less bulk in your bag.
  • The LED indicator lets you know you it’s on, and makes it easy to find in a dimly lit space.
  • Choose from three different plug orientations to save room and fit into crowded outlets.
  • Every detail has been carefully considered – from soft, bendable cables to smooth, rounded corners.
  • The new Dell Slim Power Adapter family. Powered by you.
This product is compatible with the following systems:
  • Inspiron 15 (7537)
  • Inspiron 17 (3737)
  • Inspiron 17 (7737)
  • Latitude 3330
  • Latitude 3440
  • Latitude 3540
  • Latitude E5440
  • Latitude E5540
  • Latitude E6440
  • Latitude E6540
  • Latitude E7240
  • Latitude E7440.
Dell - power adapter - 90 Watt
Power adapter - external
380 g
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Power Capacity
90 Watt
13 cm x 5.8 cm x 3.2 cm
1 year warranty
Dell Inspiron N7110; Latitude E5430, E5530, E6230
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Max Electric Current
4.62 A
Power Capacity
90 Watt
Limited warranty - 1 year
13 cm
5.8 cm
3.2 cm
380 g
Dell Inspiron N7110 , Dell Latitude E5430, E5530, E6230
