Dell P519HL DLP 4000 Lumens Projector
Quicklinx: FB6SWS00 Mfr#: DELL-P519HL
P519HL projects clear, large Full HD images ideal for medium to large spaces, such as a conference room or classroom. It uses no replacement bulbs to worry about, and there is no warmup or cooldown time, laser projection can save you time and headache. It can run 24/7 and has low power consumption, making it perfect for use in demanding environments.
Laser technology lasts for long time even in intensive use. Plus, the IP5X dust rating means your projector works beautifully even in tough, dusty environments. The P519HL is engineered to project perfectly - even on its side or upside down.
Your guests can present easily using the Dell Network Projection App Lite, which can be run without installation and can accommodate up to four presenters simultaneously. The wide range of ports allows for easy connectivity to devices and network control systems.
  • Lamp-free convenience
    With no replacement bulbs to worry about, and no warmup or cooldown time, laser projection can save you time and headache. It can run 24/7 and has low power consumption, making it perfect for use in demanding environments.
  • Consistent brightness and color
    Enjoy bright, vibrant colors the way they were meant to be seen, with 93% sRGB color.
  • Built to last
    Laser technology lasts for years. Plus, the IP5X dust rating means your projector works beautifully even in tough, dusty environments.
  • Any angle, anytime
  • Wireless presenting
    Project wirelessly over your corporate network or connect directly to the projector wirelessly with the optional WD518
  • Seamless transitions
  • Ports galore
  • Seamless management
    The RJ45 & RS232 allow you to conveniently control your projector via the network or meeting room control systems.
Dell Advanced Laser Projector P519HL - DLP projector - 3D - LAN
DLP projector - 1080p
3D Capable
Built-in Devices
Stereo speakers
Bundled Services
2 years Advanced Exchange Service
Brightness
4000 ANSI lumens
Contrast Ratio
1800:1 / 100000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
Laser
Bulb life cycle
Up to 20000 hour(s)
Video Input
LAN
Speakers
Speaker(s) - integrated
320 Watt
38.6 cm x 30.3 cm x 11.5 cm
5.7 kg
3D Capable
Built-in Devices
Stereo speakers
Bundled Services
Ethernet
Projector
Brightness
4000 ANSI lumens
Contrast Ratio
Image Size
51 cm - 762 cm
Projection Distance
1.4 m - 4.5 m
Throw Ratio
1.4 - 2.24:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
85 Hz x 100 kHz
Bulb type
Laser
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Tilt
Split Screen, Multimedia Viewer, Office Viewer, 16:10 aspect ratio support, 4:3 aspect ratio support, USB Viewer, USB Display, LAN Display, Conference Control, Audio Projection, Customisable Startup Display, Quick Shutdown
Lens
Lens Aperture
F/2.5-3.26
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Video Interfaces
VGA, HDMI
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management) , 1 x network - RJ-45 , 1 x USB 3.0 - 9 pin USB Type A (power only) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
Wireless remote control
1 x USB cable , 1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection
Security Slot Type
Kensington security slot
IP5X
Power Source
AC
320 Watt
Power Consumption Stand by
0.5 Watt
38.6 cm
30.3 cm
11.5 cm
5.7 kg
Limited warranty - lamp - 1 year
Sound Emission
36 dBA
32 dBA
