Dell P4317Q 43" 3840 x 2160 8ms VGA HDMI DP Ultra HD 4K Monitor
Quicklinx: CGVRWS00 Mfr#: P4317Q
Diagonal Size: 43in
Max Resolution: 3840 x 2160
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL) + 1 more
27 in stock
£558.42 ex VAT
£670.10 inc VAT
Increase productivity for specialized users in a single array offering crisp text, graphs and colors with this Dell multi-client monitor.
  • 4K large screen experience
    The 43 inch display with high-performance monitor scalar offers exceptional clarity up to Ultra HD 4K.
  • Multi-client capabilities
    Connect up to four independent clients to a single monitor with customized views, all without bezel breaks, so you can take total command of your tasks.
  • Simplify multi-monitor setups
    Fewer cables, single mount setup and RS232 connection offer easy manageability.
  • Clear collaboration
    Colors stay consistent across wide-angle viewing up to 178°, for impressive visibility in group settings.
  • Easy on the eyes
    The true matte finish and low reflection mean you can work comfortably, even on long days.
Display Type
Energy Class
Class B
Energy Consumption per Year
102 kWh
Power Consumption (On mode)
70 W
Diagonal Size
43"
Viewable Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
1.06 billion colours
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 2H Hard Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, Dell Custom Color, Transition Minimised Differential Signaling (TMDS) technology
97.31 cm x 25 cm x 65.8 cm - with stand
17.41 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
2 x MHL / HDMI ¦ DisplayPort ¦ VGA ¦ Mini DisplayPort ¦ USB 3.0 upstream (Type B) ¦ 4 x USB 3.0 downstream (Type A) ¦ Audio line-in (mini-jack) ¦ Headphones (mini-jack) ¦ Serial
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+10
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
VESA screw cover
1 x HDMI cable ¦ 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort ¦ 1 x DisplayPort cable - DisplayPort to DisplayPort ¦ 1 x SuperSpeed USB cable - USB Type A to B
Mounting Kit
Optional
Plug and Play, VESA EDID, DDC/CI
Security Slot Type
Kensington security slot
160 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Included Software
Display drivers, Dell Display Manager
Dimensions & Weight Details
With stand - width: 97.31 cm - depth: 25 cm - height: 65.8 cm - weight: 17.41 kg ¦ Without stand - width: 97.31 cm - depth: 8.3 cm - height: 56.64 cm - weight: 14.11 kg
Environmental Standards
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell P4317Q 43 Bundle deal on Dell P4317Q 43" 3840 x 2160 8ms VGA HDMI DP Ultra HD 4K Monitor
£657.59
Diagonal Size: 43in
Response Time: 8ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 500 - 750
