Dell P4317Q 43" 3840 x 2160 8ms VGA HDMI DP Ultra HD 4K Monitor
Quicklinx: CGVRWS00 Mfr#: P4317Q
Diagonal Size: 43in
Max Resolution: 3840 x 2160
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL) + 1 more
£526.01 ex VAT
£631.21 inc VAT
Increase productivity for specialized users in a single array offering crisp text, graphs and colors with this Dell multi-client monitor.
  • 4K large screen experience
    The 43 inch display with high-performance monitor scalar offers exceptional clarity up to Ultra HD 4K.
  • Multi-client capabilities
    Connect up to four independent clients to a single monitor with customized views, all without bezel breaks, so you can take total command of your tasks.
  • Simplify multi-monitor setups
    Fewer cables, single mount setup and RS232 connection offer easy manageability.
  • Clear collaboration
    Colors stay consistent across wide-angle viewing up to 178°, for impressive visibility in group settings.
  • Easy on the eyes
    The true matte finish and low reflection mean you can work comfortably, even on long days.
Dell P4317Q - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class B
Energy Consumption per Year
102 kWh
Power Consumption (On mode)
70 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
1.06 billion colours
Input Connectors
2xHDMI(MHL), VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 2H Hard Coating
97.31 cm x 25 cm x 65.8 cm
17.41 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI
Display Type
Energy Class
Class B
102 kWh
70 W
Diagonal Size
43"
Viewable Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, Dell Custom Color, Transition Minimised Differential Signaling (TMDS) technology
97.31 cm x 25 cm x 65.8 cm - with stand
17.41 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
2 x MHL / HDMI , DisplayPort , VGA , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-in (mini-jack) , Headphones (mini-jack) , Serial
Mechanical
Tilt
Tilt Angle
-5/+10
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
VESA screw cover
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
Mounting Kit
Optional
Security Slot Type
Kensington security slot
160 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Included Software
Display drivers, Dell Display Manager
Dimensions & Weight Details
With stand - width: 97.31 cm - depth: 25 cm - height: 65.8 cm - weight: 17.41 kg , Without stand - width: 97.31 cm - depth: 8.3 cm - height: 56.64 cm - weight: 14.11 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell P4317Q 43 Bundle deal on Dell P4317Q 43" 3840 x 2160 8ms VGA HDMI DP Ultra HD 4K Monitor
£625.18
Diagonal Size: 43in
Response Time: 8ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 500 - 750
