A better view from anywhere. Capture every nuance with the brilliance of this sleek, 4K 31.5-inch USB-C hub monitor with ComfortView Plus technology.
- Dell P3222QE - LED monitor - 4K - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class F
- Power Consumption (On mode)
- 28.3 W
- USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.18159 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (normal); 5 ms (fast)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 71.24 cm x 23.317 cm x 46.867 cm
- 9.6 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- RoHS, NFPA 99, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Designed For
- Latitude 5320, 5520; OptiPlex 3090; Precision 7560; Vostro 14 5410, 15 5510; XPS 13 9310
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.18159 mm
- Pixel Per Inch
- 139.87
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 24 - 75 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
- 71.24 cm x 23.317 cm x 46.867 cm - with stand (lowest position)
- 9.6 kg
- DisplayPort 1.4 (HDCP 2.2) , HDMI (HDCP 2.2) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 28.3 W
- Power Consumption SDR (On mode)
- 28.3 kWh/1000h
- Power Consumption (Typical)
- 28.3 Watt
- Power Consumption (Max)
- 145 Watt
- Power Consumption Stand by
- 0.2 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.2 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 71.24 cm - depth: 23.31 cm - height: 46.867 cm - weight: 9.6 kg , Without stand - width: 71.24 cm - depth: 5.618 cm - height: 41.7117 cm - weight: 5.3 kg
- Shipping Weight
- 13.4 kg
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510 , Dell XPS 13 9310
