Brand
Dell P3222QE 32" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GD4GWS00 Mfr#: DELL-P3222QE
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 5ms
Interfaces: HDMI, DisplayPort, USB-C
16 in stock
£454.31 ex VAT
£545.17 inc VAT
A better view from anywhere. Capture every nuance with the brilliance of this sleek, 4K 31.5-inch USB-C hub monitor with ComfortView Plus technology.
Dell P3222QE - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class F
Power Consumption (On mode)
28.3 W
USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.18159 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
71.24 cm x 23.317 cm x 46.867 cm
9.6 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
RoHS, NFPA 99, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Latitude 5320, 5520; OptiPlex 3090; Precision 7560; Vostro 14 5410, 15 5510; XPS 13 9310
Display Type
Energy Class
Class F
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.18159 mm
Pixel Per Inch
139.87
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
71.24 cm x 23.317 cm x 46.867 cm - with stand (lowest position)
9.6 kg
DisplayPort 1.4 (HDCP 2.2) , HDMI (HDCP 2.2) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
28.3 W
28.3 kWh/1000h
Power Consumption (Typical)
28.3 Watt
Power Consumption (Max)
145 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 71.24 cm - depth: 23.31 cm - height: 46.867 cm - weight: 9.6 kg , Without stand - width: 71.24 cm - depth: 5.618 cm - height: 41.7117 cm - weight: 5.3 kg
Shipping Weight
13.4 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510 , Dell XPS 13 9310
Diagonal Size: 32in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
Stock Status: In stock
