Dell P2720DC 27" 2560x1440 8ms HDMI USB LED LCD Monitor
Quicklinx: FQF1WS00 Mfr#: DELL-P2720DC
Do more with a 27" QHD USB-C monitor that expands your workspace. Get a better view of all your important tasks while reducing cable clutter.
  • Ideal for collaboration
    Single-cable connectivity enables quick transitions from your desk and offers the flexibility of connecting to multi-vendor USB-C systems.
  • Flexibility for all day comfort
    With the ability to tilt, swivel, pivot and adjust the height of your monitor to fit your needs, you can stay comfortable all day.
  • Easy on the eyes
    Optimize eye comfort with a flicker-free screen and ComfortView, a feature that reduces up to 60% of harmful blue light emissions.
  • Enjoy the view
    Experience virtually seamless views with consistent colors across a wide 178°/178° viewing angle with In-Plane Switching (IPS) technology.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
Dell P2720DC - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
21.7 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey), 8 ms (normal)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
61.16 cm x 18.5 cm x 39.53 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520; Precision 7560; XPS 13 9310
Display Type
Energy Class
Class E
34 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
108
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
LED edgelight system, Energy Gauge, Mercury free, arsenic-free glass
61.16 cm x 18.5 cm x 39.53 cm - with stand
DisplayPort 1.2 , HDMI , USB-C , DisplayPort 1.2 output
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 mm, VESA
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB-C cable
Input Voltage
21.7 W
21.7 kWh/1000h
Power Consumption (Typical)
24.5 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - width: 61.16 cm - depth: 4.36 cm - height: 36.41 cm - weight: 4.97 kg , With stand - width: 61.16 cm - depth: 18.5 cm - height: 39.53 cm
Shipping Weight
9.53 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
10 - 90% (non-condensing)
Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310
