Do more with a 27" QHD USB-C monitor that expands your workspace. Get a better view of all your important tasks while reducing cable clutter.
Ideal for collaboration
Single-cable connectivity enables quick transitions from your desk and offers the flexibility of connecting to multi-vendor USB-C systems. -
Flexibility for all day comfort
With the ability to tilt, swivel, pivot and adjust the height of your monitor to fit your needs, you can stay comfortable all day. -
Easy on the eyes
Optimize eye comfort with a flicker-free screen and ComfortView, a feature that reduces up to 60% of harmful blue light emissions. -
Enjoy the view
Experience virtually seamless views with consistent colors across a wide 178°/178° viewing angle with In-Plane Switching (IPS) technology. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup. -
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
- Dell P2720DC - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 21.7 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey), 8 ms (normal)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.16 cm x 18.5 cm x 39.53 cm
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 13 9310
- Display Type
- Energy Class
- Class E
- 34 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 108
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system, Energy Gauge, Mercury free, arsenic-free glass
- 61.16 cm x 18.5 cm x 39.53 cm - with stand
- DisplayPort 1.2 , HDMI , USB-C , DisplayPort 1.2 output
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 mm, VESA
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB-C cable
- Input Voltage
- 21.7 W
- Power Consumption SDR (On mode)
- 21.7 kWh/1000h
- Power Consumption (Typical)
- 24.5 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 61.16 cm - depth: 4.36 cm - height: 36.41 cm - weight: 4.97 kg , With stand - width: 61.16 cm - depth: 18.5 cm - height: 39.53 cm
- Shipping Weight
- 9.53 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310
