This screen with 3-sided ultra-thin bezels is designed for seamless multi-display productivity with your all in one. Its small base frees valuable workspace.
- Dell P2719H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class D
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 15.1 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (normal); 5 ms (fast)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 60.99 cm x 18.5 cm x 39.43 cm
- 6.28 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
- 3-year warranty
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 5320, 5520, 7400 2-in-1; Precision 7560; XPS 13 9380, 15 9570
- Display Type
- Energy Class
- Class D
- 27 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
- 60.99 cm x 18.5 cm x 39.43 cm - with stand
- 6.28 kg
- DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15.1 W
- Power Consumption SDR (On mode)
- 15.1 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 60.99 cm - depth: 4.28 cm - height: 36.3 cm - weight: 4.35 kg , With stand - width: 60.99 cm - depth: 18.5 cm - height: 39.43 cm - weight: 6.28 kg
- Shipping Weight
- 9.05 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520, 7400 2-in-1 , Dell Precision 7560 , Dell XPS 13 9380, 15 9570
