Dell P2719H 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: DVQWWS00 Mfr#: DELL-P2719H
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15), DisplayPort
£175.17 ex VAT
£210.20 inc VAT
This screen with 3-sided ultra-thin bezels is designed for seamless multi-display productivity with your all in one. Its small base frees valuable workspace.
Dell P2719H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class D
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
15.1 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
60.99 cm x 18.5 cm x 39.43 cm
6.28 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
3-year warranty
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
Energy Class
Class D
27 kWh
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
60.99 cm x 18.5 cm x 39.43 cm - with stand
6.28 kg
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
15.1 W
15.1 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 60.99 cm - depth: 4.28 cm - height: 36.3 cm - weight: 4.35 kg , With stand - width: 60.99 cm - depth: 18.5 cm - height: 39.43 cm - weight: 6.28 kg
Shipping Weight
9.05 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: Dell
