Brand
Dell P2719H 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: DVQWWS00 Mfr#: DELL-P2719H
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, VGA (HD-15)
Hurry, only 1 left in stock!
£197.69 ex VAT
£237.22 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
This screen with 3-sided ultra-thin bezels is designed for seamless multi-display productivity with your all in one. Its small base frees valuable workspace.
Dell P2719H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class D
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
15.1 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
60.99 cm x 18.5 cm x 39.43 cm
6.28 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
3-year warranty
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 5320, 5520, 7400 2-in-1; Precision 7560; XPS 13 9380, 15 9570
Display Type
Energy Class
Class D
27 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
60.99 cm x 18.5 cm x 39.43 cm - with stand
6.28 kg
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
15.1 W
15.1 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 60.99 cm - depth: 4.28 cm - height: 36.3 cm - weight: 4.35 kg , With stand - width: 60.99 cm - depth: 18.5 cm - height: 39.43 cm - weight: 6.28 kg
Shipping Weight
9.05 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 5320, 5520, 7400 2-in-1 , Dell Precision 7560 , Dell XPS 13 9380, 15 9570
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: Dell
Stock Status: While stocks last
Stock Status: Clearance
