Dell P2717H 27" 1920x1980 6ms HDMI VGA LED Monitor
Quicklinx: C5BNWS00 Mfr#: P2717H
More productive than ever. The Dell P2717H brings a different level of productivity to the work place without sacrificing comfort and convenience.
Dell P2717H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
62.1 cm x 20 cm x 41.5 cm
7.44 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class A+
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Ultra wide viewing angle, Dell Easy Arrange, Dell ComfortView
62.1 cm x 20 cm x 41.5 cm - with stand
7.44 kg
HDMI , DisplayPort , VGA , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
23 Watt
Power Consumption (Max)
55 Watt
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Bundled Services
