More productive than ever. The Dell P2717H brings a different level of productivity to the work place without sacrificing comfort and convenience.
- Dell P2717H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.1 cm x 20 cm x 41.5 cm
- 7.44 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Ultra wide viewing angle, Dell Easy Arrange, Dell ComfortView
- Black
- 62.1 cm x 20 cm x 41.5 cm - with stand
- 7.44 kg
- HDMI , DisplayPort , VGA , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 23 Watt
- Power Consumption (Max)
- 55 Watt
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Bundled Services
