Exceptional screen clarity.
The Dell 27 Ultra HD 4K monitor has gorgeous resolution. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford.
Nearly perfect color accuracy.
You can count on natural and consistent color across different mediums because each monitor is factory tuned at 99% sRGB with a color calibration factory report certifying that each monitor has a deltaE < 3. That means you get precise color coverage right out of the box at an amazing high-color depth of 1.07 billion colors. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle at 178°/ 178°.
Full adjustability.
Enjoy every detail the Dell 27 Ultra HD 4K Monitor - P2715Q provides in total comfort, thanks to full adjustability.
- The included stand enables tilt (5° forward or 21° backward), pivot, swivel and even provides built-in cable-management.
- Customize your viewing experience with a height-adjustable stand, or save desktop space by detaching the stand for wall mounting with a VESA-compatible 100mm x 100mm wall mount kit. (Wall mounting equipment sold separately.)
All-digital connectivity.
Connect easily with other peripherals simultaneously, and view content from your handheld devices on the monitor screen - all without compromising picture quality.
- With DisplayPort 1.2, you can daisy-chain two monitors side by side by connecting via the DP-in and DP-out ports, eliminating the need to link every one of your monitors to the PC and reducing cable clutter.
- Charge or power BC1.2-compatible and other USB devices with a high-speed USB 3.0 charging port.
- Connect to MHL compatible smartphone or tablet and display content directly on the larger monitor screen via MHL.
Eco-conscious design.
The Dell 27 Ultra HD 4K Monitor - P2715Q meets the latest regulatory and environmental standards.
- ENERGY STAR® Qualified
- EPEAT® Gold3 Rated
- TCO Certified Displays
Made with premium-quality materials, this Ultra HD 4K monitor is BFR/PVC-free (excluding external cables) and has arsenic-free glass, a mercury-free LED panel, and a chassis made of more than 25 percent post-consumer recycled materials.
The Dell 27 Ultra HD 4K monitor has gorgeous resolution. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford. -
You can count on natural and consistent color across different mediums because each monitor is factory tuned with a color calibration factory. That means you get precise color coverage right out of the box at an amazing high-color. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle. -
Full adjustability
Enjoy every detail the Dell 27 Ultra HD 4K monitor - P2715Q provides in total comfort, thanks to full adjustability. -
Connect easily with other peripherals simultaneously, and view content from your handheld devices on the monitor screen - all without compromising picture quality. -
The Dell 27 Ultra HD 4K monitor - P2715Q meets the latest regulatory and environmental standards.
- Dell P2715Q - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 104% (CIE 1976), 77.6% (CIE 1931), 99% sRGB
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.074 cm x 20.386 cm x 42.386 cm
- 7.18 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VESA EDID, DDC/CI
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 6 ms
- Vertical Refresh Rate
- 29 - 76 Hz
- Horizontal Refresh Rate
- 31 - 140 kHz
- Video Bandwidth
- 533.25 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, sharpness, rotation, input select, colour temperature, uniformity, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, Multi-Stream transport (MST), Energy Gauge, Energy Saver, Mercury free, Factory Calibration, Transition Minimised Differential Signaling (TMDS) technology, 99% sRGB colour gamut
- Black
- 64.074 cm x 20.386 cm x 42.386 cm - with stand
- 7.18 kg
- 4 x USB 3.0 downstream , USB 3.0 upstream , MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output (MST) , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Rotation Angle
- 180
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 30 W
- Power Consumption (Typical)
- 95 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 64.074 cm - depth: 20.386 cm - height: 42.386 cm - weight: 7.18 kg , Without stand - width: 64.074 cm - depth: 5.15 cm - height: 37.966 cm - weight: 5.03 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
