Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: HWNXWS00 Mfr#: DELL-P2425H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 In Stock
£113.69 ex VAT
£136.42 inc VAT
Stay productive. Get enhanced visual comfort and seamless connectivity with this FHD monitor, certified by TÜV for 4-star eye comfort.
  • Improved ComfortView Plus
    Reduces harmful blue light emissions to =35%, for all-day comfort without sacrificing color.
  • Refresh rate
    100 Hz refresh rate delivers less flicker, more seamless scrolling and smoother motion.
  • Vivid colors
    Wide color coverage with up to 16.7 m displayable colors of 99% sRGB.
  • Color consistency
    Vibrant colors across wide viewing angles enabled by In-Plane Switching (IPS) technology.
  • 1500:1 contrast ratio
    For deeper blacks and brighter whites.
  • Extensive connectivity
    Wide variety of ports for all your accessories.
  • Quick access USB ports
    Including a USB-C downstream that delivers up to 15W of power.
  • Design innovation
    This monitor has been thoughtfully crafted with sustainable materials including 85% recycled plastics with post-consumer recycled plastic and closed-loop ITE-derived plastic, 50% recycled steel, 100% recycled aluminum and at least 20% recycled glass.
  • Energy conservation
    Using PowerNap mode in Dell Display Manager lowers energy use by up to 14.8%.
  • Excellence in environmental standards
    This monitor is certified ENERGY STAR 8.0, carries the TCO Certified Edge designation, and is registered EPEAT Gold with Climate+. With Climate+, this monitor has met industry best practices around decarbonization.
Dell P2425H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1865623
Energy Class
Class C
Power Consumption (On mode)
11.7 W
USB 3.2 Gen 1 hub, USB PD 15 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1500:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 18.175 cm x 36.4 cm
4.61 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
Carbon Footprint
155 kg carbon emissions
Plug and Play, RoHS, BFR-free, PVC-free
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class C
Diagonal Size
24"
Viewable Size
23.81"
Built-in Devices
USB 3.2 Gen 1 hub
USB Power Delivery
15 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.53
Brightness
250 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
4.61 kg
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
11.7 W
11.7 kWh/1000h
Power Consumption (Typical)
12 Watt
Power Consumption (Max)
65 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dimensions & Weight Details
With stand (lowest position) - width: 53.864 cm - depth: 18.175 cm - height: 36.4 cm - weight: 4.61 kg , With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 4.61 kg , Without stand - width: 53.864 cm - depth: 5.003 cm - height: 31.423 cm - weight: 3.12 kg
Shipping Weight
6.78 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
80.6
Logistics (kg CO2e)
12.71
Use (kg CO2e)
57.66
EOL (kg CO2e)
4.03
Total Carbon w/o Use Phase (kg CO2e)
97.34
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
HWNX Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (2)
HWNX Dell SB521A Magnetic Sound bar In Stock £39.93
HWNX Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
