Brand
Dell P2421D 23.8" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: G2YYWS00 Mfr#: DELL-P2421D
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: HDMI, DisplayPort
More than 50 in stock
£205.02 ex VAT
£246.02 inc VAT
See more and do more with a QHD monitor that expands your workspace and gives you a better view of all of your important tasks.
  • Expand your productivity workspace
    This screen with QHD 2560 x 1440 resolution delivers more onscreen real estate than Full HD.
  • Productive at every level
    Easy Arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you time, allowing quick access to commonly used controls that let you work faster.
  • Flexibility for all day comfort
    With the ability to tilt, swivel, pivot and adjust the height of your monitor to fit your needs, you can stay comfortable all day.
  • More screen
    The small base takes up less space helping tidy up your desk.
  • Easy on the eyes
    Optimize eye comfort with flicker-free technology and ComfortView, a feature that reduces up to 60% of harmful blue light emissions.
  • Enjoy the view
    Experience virtually seamless views with consistent colors across a wide 178°/178° viewing angle with In-Plane Switching (IPS) technology.
Dell P2421D - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
16.9 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
53.78 cm x 16.6 cm x 35.61 cm
4.91 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 5320, 5520; OptiPlex 3090; Precision 7560
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
49 - 75 Hz
Horizontal Refresh Rate
29 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, arsenic-free glass, Wide Viewing Angle, 6-bit + A-FRC Color Depth, 99% sRGB colour gamut
53.78 cm x 16.6 cm x 35.61 cm - with stand
4.91 kg
DisplayPort 1.2 , HDMI , USB 3.0 upstream , 2 x USB 3.0 downstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB 3.0 upstream cable
Input Voltage
16.9 W
16.9 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.78 cm - depth: 16.6 cm - height: 35.61 cm - weight: 4.91 kg , Without stand - width: 53.78 cm - depth: 4.27 cm - height: 32.21 cm - weight: 3.37 kg
Shipping Weight
7.29 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
10 - 90% (non-condensing)
Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Dell
Stock Status: In stock
