The Dell 24 monitor - P2416D engages you in remarkable quad HD resolution with 1.77 times more details than Full HD and a wide 99% sRGB color coverage. Enjoy the convenience of multiple USB ports, organize applications in a snap on one screen with Dell easy arrange, and maximize productivity with multiple adjustability features.
Remarkable screen performance
The Dell 24 monitor - P2416D engages you in remarkable quad HD resolution with 1.77 times more details than Full HD and a wide 99% sRGB color coverage. -
Unrivaled usability
Enjoy the convenience of multiple USB ports, organize applications in a snap on one screen with Dell easy arrange, and maximize productivity with multiple adjustability features. -
Designed for peace of mind
Dell 24 monitor - P2416D is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the premium panel guarantee.
- Dell P2416D - LED monitor - 24" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.205 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.56 cm x 20.5 cm x 36.9 cm
- 5.95 kg
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.75"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.205 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 49 - 86 Hz
- Horizontal Refresh Rate
- 29 - 113 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
- Stand lock, Energy Gauge, 99% sRGB colour gamut
- Black
- 56.56 cm x 20.5 cm x 36.9 cm - with stand
- 5.95 kg
- Bundled with
- DisplayPort , HDMI , VGA , USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5.5/+22
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Plug and Play
- Localisation
- United Kingdom
- Input Voltage
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 56.56 cm - depth: 4.7 cm - height: 33.51 cm - weight: 3.58 kg , With stand - width: 56.56 cm - depth: 20.5 cm - height: 36.9 cm - weight: 5.95 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
