Dell P2319H 23" Full HD (1080p) 8ms HDMI, VGA LED Monitor
Quicklinx: DWY3WS00 Mfr#: DELL-P2319H
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£125.43 ex VAT
£150.51 inc VAT
Optimize your workspace with this efficient 23" monitor built with an ultrathin bezel design, a small footprint and comfort-enhancing features.
  • Expand your efficiency
    The three-sided ultrathin bezel design lets you enjoy an uninterrupted view of your content across multiple monitors. And, with dual monitors, you can increase your productivity.
  • More ways to multitask
    Work conveniently across multiple screens and select from predefined templates with the Easy Arrange feature on Dell Display Manager software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off.
  • Consistent and rich colors
    A wide viewing angle enabled by In-Plane Switching (IPS) technology lets you see vibrant colors - no matter where you sit.
  • Clean and clutter-free
    Focus on your work while hiding away cable clutter with an improved cable management design.
  • Easy on the eyes
    This monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over extended viewing.
  • Adjust to your comfort
    Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long.
Dell P2319H - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A+
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
52 cm x 16.6 cm x 35.11 cm
4.78 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 7400 2-in-1; XPS 15 9570
Display Type
Energy Class
Class A+
23 kWh
16 W
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
52 cm x 16.6 cm x 35.11 cm - with stand
4.78 kg
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
16 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 52 cm - depth: 4.13 cm - height: 31.17 cm - weight: 3.11 kg , With stand - width: 52 cm - depth: 16.6 cm - height: 35.11 cm - weight: 4.78 kg
Shipping Weight
7 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 15 9570
Dell P2319H 23 Bundle deal on Dell P2319H 23" Full HD (1080p) 8ms HDMI, VGA LED Monitor
£224.60
Diagonal Size: 23in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
