Optimize your workspace with this efficient 23" monitor built with an ultrathin bezel design, a small footprint and comfort-enhancing features.
Expand your efficiency
The three-sided ultrathin bezel design lets you enjoy an uninterrupted view of your content across multiple monitors. And, with dual monitors, you can increase your productivity. -
More ways to multitask
Work conveniently across multiple screens and select from predefined templates with the Easy Arrange feature on Dell Display Manager software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off. -
Consistent and rich colors
A wide viewing angle enabled by In-Plane Switching (IPS) technology lets you see vibrant colors - no matter where you sit. -
Clean and clutter-free
Focus on your work while hiding away cable clutter with an improved cable management design. -
Easy on the eyes
This monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over extended viewing. -
Adjust to your comfort
Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long.
- Dell P2319H - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class E
- Power Consumption (On mode)
- 14.8 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 52 cm x 16.6 cm x 35.11 cm
- 4.78 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
- 52 cm x 16.6 cm x 35.11 cm - with stand
- 4.78 kg
- DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.8 W
- Power Consumption SDR (On mode)
- 14.8 kWh/1000h
- Power Consumption (Typical)
- 16 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 52 cm - depth: 4.13 cm - height: 31.17 cm - weight: 3.11 kg , With stand - width: 52 cm - depth: 16.6 cm - height: 35.11 cm - weight: 4.78 kg
- Shipping Weight
- 7 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560
