The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards.
Please note this monitor does not come with a stand
Flexible viewing features
The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. -
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. -
Designed for professionals
For large and small businesses, the P2214H is ideal for Latitude, OptiPlex and Dell Precision systems driving high-performance business applications. It is also an excellent display for Latitude and XPS systems in home-office environments. -
Environment-conscious design
The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards. -
Energy-efficient design
With 26 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2214H can help keep energy costs down. Manage power consumption wisely with PowerNap, which you can enable through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use. -
Outstanding screen clarity for productive offices
Bright, clear with the viewing features and connectivity options that help boost productivity in business and at home.
- Dell P2214H - without stand - LED monitor - Full HD (1080p) - 22" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
- LED-backlit LCD monitor - 22"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 51.27 cm x 4.63 cm x 30.44 cm
- 3.26 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, DDC/CI, RoHS, CECP
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- HDCP
- Black
- 51.27 cm x 4.63 cm x 30.44 cm - without stand
- 3.26 kg
- Bundled with
- DVI-D (HDCP) , DisplayPort , VGA , USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream (Type A)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £26.51 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
