Give your productivity a boost with the comfortable design and convenient features of a high-performance, energy-conscious HD 22" monitor with LED. Tilt, swivel and pivot your screen and adjust its height to suit your personal work style, plus plenty of convenient ports enable you to work in comfort.
Whether you're using the P2213 to manage complex spreadsheets or to create your next big presentation, being productive has never felt better. Find your inspiration in every colorful detail. The 22" P2213 monitor will motivate and captivate with clarity, performance and visual precision.
Please note this monitor does not come with a stand.
Choose your view
The P2213 offers full adjustability features such as tilt, swivel, pivot and a broad height adjustment range. You can even mount it to the wall to save valuable desk space. -
Make your connections
Easily connect your desktop or laptop to the P2213 via a standard VGA port, or take advantage of the DVI connector, which can present an outstanding digital image. Two convenient USB ports offer connectivity for your peripheral devices such as mice, webcams, keyboards and more. -
Performance fosters productivity
Find your inspiration in every colorful detail. The 22" P2213 monitor will motivate and captivate with clarity, performance and visual precision. -
Enjoy crisp, clear images
Experience the sharp imagery provided by 1680x1050 at 60 Hz HD resolution and a high dynamic contrast ratio, all on a 16:10 aspect ratio widescreen. -
Discover a world of color
Your presentations, slideshows and image-intensive documents will come to life on the P2213, featuring a high color gamut and an impressive color depth. -
Take responsibility for your business and the environment
Invest in a reliable, energy-conscious monitor designed to help minimize environmental impact, maximize business value, and control operating costs. -
Consume less energy
Active-off mode helps avoid wasting power when your monitor is idle. Dynamic dimming helps ensure you only use as much energy as your applications require. Mercury-free LED backlight is a low-energy light source that helps lower your power consumption. -
Contain business expenses
A stable, reliable life cycle helps ensure that your investment today will provide product line consistency for the future and help preserve your budget. -
Conserve the environment
The P2213 features an eco-conscious design with arsenic-free glass and a mercury-free panel. The monitor uses post-consumer recycled materials in its chassis.
- Dell P2213 - without stand - LED monitor - 22" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
- LED-backlit LCD monitor - 22"
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 51.04 cm x 5.98 cm x 33.27 cm
- 3.43 kg
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Diagonal Size
- 22"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, PowerNap, Dynamic Dimming
- Black
- 51.04 cm x 5.98 cm x 33.27 cm - without stand
- 3.43 kg
- Bundled with
- VGA (HD-15) , DVI-D (HDCP) , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x USB cable , 1 x DVI cable
- Localisation
- United Kingdom
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
