Dell P2018H 19.5" 5 ms 1600 x 900 at 60Hz Black LED
Quicklinx: DXB2WS00 Mfr#: DELL-P2018H
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£115.98 ex VAT
£139.17 inc VAT
Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
  • Screen performance
    View your applications, spreadsheets and more on a 19.5-inch monitor with 1600 x 900 HD clarity, 16.7 million colors, and a contrast ratio of 1000:1.
  • Work comfortably
    The flicker-free screen with ComfortView, a feature which helps reduce harmful blue light emissions, optimizes eye comfort.
  • Auto mode and PowerNap
    Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
Dell P2018H - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Class
Class A
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
14 W
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
46.15 cm x 18 cm x 33.88 cm
Environmental Standards
ENERGY STAR Qualified
CECP, CEL, TUV Rheinland Low Blue Light Certification
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Latitude 7400 2-in-1
Display Type
Energy Class
Class A
24 kWh
14 W
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Per Inch
94
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
72% (CIE 1931) colour gamut, 84% (CIE 1976) colour gamut, PowerNap, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Dell ComfortView
46.15 cm x 18 cm x 33.88 cm - with stand
DisplayPort , HDMI , VGA , 2 x USB 2.0 downstream , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x SuperSpeed USB cable , 1 x VGA cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
14 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 46.15 cm - depth: 18 cm - height: 33.88 cm , Without stand - width: 46.15 cm - depth: 5.01 cm - height: 27.32 cm - weight: 2.4 kg
Shipping Weight
6.13 kg
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1
Dell P2018H 19.5 Bundle deal on Dell P2018H 19.5" 5 ms 1600 x 900 at 60Hz Black LED
£215.15
Diagonal Size: 20in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
