Dell P2017H 19.5" 1600x900 6ms LED HDMI VGA Monitor
Quicklinx: C8P7WS00 Mfr#: P2017H
More productive than ever. The Dell 20 Monitor P2017H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
  • Purposefully designed for comfort and convenience
    With a full range of adjustable features, slim borders and multiple connectivity ports.
  • Enhanced viewing experience
    Dell ComfortView and flicker-free feature make work less strenuous when viewing vividly clear visuals across an ultrawide viewing angle.
  • Reliable and responsible
    Get complete piece of mind with Premium Panel Guarantee, Advanced Exchange Service and an eco-friendly design.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
Dell P2017H - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Class
Class A+
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
46.2 cm x 18 cm x 33.9 cm
4.73 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A+
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
46.2 cm x 18 cm x 33.9 cm - with stand
4.73 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
1 x VGA cable - VGA to VGA , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
Input Voltage
Sustainability Information
ENERGY STAR Certified
C8P7 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
